Will having 4gb Ram on WinXp 32 pro Bog your system down??
This is probably a silly question, but I am curious what others have to say on this....
I have been running 2x1gb ddr 800 sticks on my pc for a while now. Well the same sticks were on sale so I got another 2x1gb for the heck of it. I realize my version of windows can only see 3gb, but will that bog my system down since only 2 are being run in dual channel mode? Can to much on-board memory in xp 32 actually slow your system a bit??
Thanks for looking :hello:
11 answers Last reply
More about will winxp system down
  1. Short answer; no, running large amounts of RAM will not bog down the system.
  2. No it should not....in fact it should be more responsive under ram intensive apps since it will have to hit the hard drive less often to page(swap)...
  3. If you are losing dual channel for whatever reason, yes it will be slower. I don't know why you would though.
    Otherwise, no it won't slow you down in any meaningful way. It may run at the 2t command rate instead of 1t, but since you are asking this question, you probably won't care or notice.
  4. It won't bog you down, but it might not be the best performance upgrade for your system. For example, adding a second hard drive (not RAID) would give you a lot more bang for the buck if you're only running one, effectively doubling your data I/O.
  5. My system has 2x2GB and XP32 and it's not bogged down at all. I see 3.25 GB. Other people (with different video cards) see 3.5. You should be fine.
    Are you sure that only 2 of the 4 sticks will run in dual-channel mode? Did you read that in the motherboard's manual? I would expect it to work with 4 sticks. Either way, it won't hurt performance noticeably, and when things get really tough and the additional memory is actually used you'll see a huge performance gain.
    http://en.wikipedia.org/wiki/Dual-channel_architecture
  6. Sounds like you are assuming no dual channel mode but why? The OS takes what it can of the extra two RAM sticks and runs them in DC too. Unless your MOBO manual states otherwise.
  7. Almost every board will run dual channel just fine....
    I have 4 sticks and its dual symmetrical....most Intel chipsets will even run dual channel with 3 sticks(asymmetrical...slight performance hit....but at least you can do it)....
    just get CPU-Z and see for your self what its running in
    http://www.cpuid.com/cpuz.php
  8. I'm running 4GB and XP.. man my computer sure is slow.
    You are kidding, right? That Q6700/8800GT combination should be very fast. Have you tried 3dMark06? What's your score?
    Edit: I get 12000, with a slower CPU and slightly faster GPU, and the rest almost identical. You should get about the same thing IMO, or maybe 14000.
  10. You should be able to run all four sticks in DC mode. You might drop to 2t command rate, or the ram might drop down in frequency/have looser timings, but I'm not sure if the system will be slower overall. If you use programs that require lots of ram, they will probably run faster overall due to needing to use the swap file less. However, you your ram uses never exceeded 2GBs, you could find things running a bit slower. (2t command rate @ 5-5-5-15 instead of 1t command rate at 4-4-4-12)
  11. Thanks folks :) Great input!! I was assuming DC mode wasnt working software side because my OS was only seeing 3gb. One should never assume :)
Memory RAM
