I plan to build by Feb. I have never tried to build a comp and have been doing a ton of research before I try it. Let me know what you guys think of this build. I was hoping to keep it under 1500 but right now it's close to 1700. I want to build mainly for gaming. I plan to play Age of Conan. I might try to OC. I don't know how but it's an option in the future. I think for now I am best just buying parts that are good regardless if I ever OC or not. Everything listed is from Newegg. I have a question about the OEM stuff. If buy an OEM hard drive will it come with all the wires needed? Should even buy OEM stuff since this is my first build?
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM $33.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
COOLER MASTER Stacker RC-832-KKN1-GP Black Aluminum ATX Full Tower Computer Case $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119121
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
ASUS EN8800GT/G/HTDP/512M GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121099
$279.00
PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W Power Supply - Retail
Item #: N82E16817703009
Return Policy: Standard Return Policy
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
-$81.00 Instant
$249.99
$168.99
Crucial Ballistix 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
100.00 after rebate.
ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard - Retail
Item #: N82E16813131219
Return Policy: Limited Non-Refundable 30-Day Return Policy
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219
$226.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600 - Retail
Item #: N82E16819115017
Return Policy: Processors (CPUs) Return Policy
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
$279.99
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM
Item #: N82E16832116204
Return Policy: Software Return Policy
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116204
$111.49
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
http://www.newegg.com/product/product.asp?item=N82E16835186134
21.99
New Total 1563.00
$279.00
-$81.00 Instant
$249.99
$168.99
$226.99
$279.99
$111.49
21.99
New Total 1563.00
