Well the Zalman Reserator 1 V2 take me to 4GHz?(Water Cooling System)
Yager
16
Not gonna happen
I'd say 3.6 max
goodie
232
surely if he has a good VID it will get him to 3.8.
i've heard quite a few people getting 3.8 with a TRUE
iluvgillgill
Splendid
Jan 1, 2007
3,732
TRUE can do 3.8 on the Q6600 but i saw some review that WC kit he's got cant match the best of aircool. which unfortunately its the TRUE and Xiggy. so the answer to OP IS NO!sorry.
Lupiron
1,711
Wow, no one asks him to run Core Temp and list his VID?
We already know that if he just got it retail, its 1.3000 or higher.
How about Waly, list it!
--Lupi
HoLLoW
4
If you want to take it to the 4GHz SAFELY then you will need a dedicated CPU cooler which must be either a Peltier Effect Block+Water Cooling OR a Phase-Change Unit like one offered by OCZ. http://www.ocztechnology.com/products/cooling_products/ocz_cryo_z
for a surprisingly low 300$ US
Lupiron
1,711
I agree with HoLLoW.
Try 1 of these:
http://jab-tech.com/Black-Ice-GTX-480-Radiator-pr-3614.html
Then 4 of these:
http://www.sidewindercomputers.com/de12tfexhisp.html
Try one of these too:
http://jab-tech.com/Apogee-GTX-Extreme-Performance-CPU-Waterblock-pr-3730.html
The Res and pump should also be good, but you have more lee way on getting good gear. Use the largest tubings they all support.
I did alot of testing on the q6600 series, and you'll need some serious voltage to reach 4.0 stable in prime for over an hour. (yet alone, 8 hours.)
And Run Core Temp, and list your VID. That's gonna be a big factor right there. Hope it isn't a retail q6600 from, say, between now and 4 months ago. Gonna be a 1.3000 or worse if it was! :(
--Lupi
Lupiron
1,711
Gill! Prolly any case you wanna mod the side will house it. Other than that, a double tower case! I found one, some dude was trashing it, and it's one of those that house double mobos!
So I can use the upper Mobo area for water junk, and anything else, and still have a tower size case left, lol!!
Got me, haven't done the measuring yet!
And I need to build a 300 watt fan controller. The fans pull 30 watts each! x 4! And just in case I do a push pull, thats 8 fans! WoW! Need that 300 watts!
--Lupi
Lupiron
1,711
Damn, they are always out of stock on the good gear!!!
That Rad looks interesting!!
Were is my Padawan? He is supposed to do the research, I just read the review, and fork over the cash!
--Lupi
rubix_1011
Contributing Writer
Yeah, I thought about that radiator, but went with a transmission and oil cooler for cars; 1/2" ID all copper tubing, all copper fins. I had to connect the 2 coolant passages with a loop and it gave me an 8-pass passive heat exchanger in addition to my 2x120mm BlackIce.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DER-15902B&N=700+0&autoview=sku
