need help with parts
Forum Homebuilt Systems : New System Build - need help with parts
Hi, im looking at replacing some parts from my pc, that will run games for a few years.
Im looking at the following parts could you tell me if they will work together or if i should change some:
Gigabyte GA-MA69VM-S2 http://www.amazon.co.uk/gp/product [...] e=&seller=
AMD Athlon 64 X2 5000+ http://www.ebuyer.com/product/1356 [...] e=extended
Nvidia 8800 GT, 512MB http://www.xtsit.com/browse/produc [...] 11873&sr=2
(x2) Kingston 1gb DDR2 800mhz/PC2-6400 Non-ecc CL5 http://www.ebuyer.com/product/120446
And i am using the same HD and CD drive from my pc at the moment:
LG GSA-4167B 16x Super multi DVD/CD rewriter
80gb maxtor 6V080E0 SATA drive
so will these run or will i have to change some?
Sponsored Links
Perfect! They're compatible & will run well as a gaming pc.
Reply to akhilles
cool cheers for advice : )
Reply to mrplow99
Tom's Hardware > Forum > Homebuilt Systems > New System Build > need help with parts
There are 1001 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
