I'm going to put together a PC for the first time in February/March. I've done some research but I'm still a beginner so I'd appreciate any advice you can give me. One thing is especially important, though: my system should be as future-proof as possible (within financial limits ). I bought my last PC pre-built, it had a socket A motherboard with an AGP port for graphics cards which went out of style only a few months after purchase, so I never was able to upgrade it. I'd like to avoid this kind of mistake this time. I know the evolutions in hardware can't always be predicted, but if you know of a certain technology that's coming soon and that will likely supplant the current standard quickly, please let me know here.
My PC will be used for pretty much everything: games, high definition media, work and general idling. I'd like to keep the price below 2000€, including the screen.
So here's a draft of what my PC might look like:
■Antec Performance One P182 Case ~140€: I've heard it's both handy and silent, the second point being the most important since I'll be watching movies on my PC. Bit expensive for my tastes, maybe, but if it's worth the price, why not...
■Corsair TX650W PSU ~115€: Maybe 650W is overkill? If it is, I'm also considering the Seasonic S12II-500 ~100€.
■Not sure about the motherboard. SLI doesn’t seem to be all that useful (Tri-SLI is just ridiculous) and DDR3 apparently isn't worth the price. If I had to choose, I'd probably go for DDR3 over SLI since it could become a new standard, but I'm not sure so that's why I'm asking you guys. SLI + DDR3 is apparently not yet an option, though I've heard they're working on it. Is it worth waiting for?
■Intel Core 2 Quad Q9450 2.66Ghz ~350€. I definitely want to jump on board with the Penryn generation. Especially since I'll also be doing video conversion and the new SSE4 should be useful.
■ 4GB (2x2GB) of OCZ Platinum DDR2 PC6400 CL5-5-5-4 ~90€. Or should I get PC8500 or higher? Or DDR3? I've done some reading on FSB speeds and the new Quad processor will have a FSB of 1333Mhz, so should I get 1333Mhz RAM or will it not make much difference anyway? Also, I've heard that more than 3GB of RAM isn't recognized by 32bit versions of Windows and that Vista 64bit is crap. What's your opinion on this? Considering the low price of memory getting 3GB when you can get 4GB is rather disappointing.
■GeForce 8800GT ~270€. I was considering getting two, but I think I'd rather just use one and upgrade once something better comes along. One thing that worries me here is that most nVidia cards don't have an HDMI out. My screen will have an HDMI in, so wouldn't it be preferable to use HDMI over DVI? The ATI cards do have HDMI but they always come out worse in the comparisons... Or is the GeForce 9xxx series coming too soon for the 8800GT to be worth it?
■2 x Western Digital Caviar SE16 500GB SATA2 16MB 7200RPM ~190€.
■Samsung SH-S203B DVD-writer ~35€ OR one of LG’s hybrid HD-DVD/Blu-Ray drives at ~300€. Anyone know if the LG drive is worth the price? And is there any competition coming in the HDDVD/Blu-ray combo department?
■IIyama 24″ Wide ProLite B2403WS-B1 screen at ~420€. Has HDMI and can go up to full 1080p resolution. Rather expensive, though. Problem is, no 22" screen can do full HD...
■Should I get an additional heatsink/fan for my CPU? Any advice on which one to get? Extra casefans? Again, noise is an important factor. I might not overclock much but I like to keep the possibility open.
■I might add an Auzentech soundcard, but only if my budget permits.
I appreciate any advice you can give me!
