I Built a system some months back and my power supply is faulty I think. In the bios and pcprobe it says the 12v is only 11.8 and dips to 11.73 sometimes. I RMAed it and they said it was fine. I figure I need a new power supply though. This is what I got...
http://www.newegg.com/product/product.asp?item=N82E16817171018
My roommate got the same one and his works fine so thats kind of annoy but anyway...
My computer is a
AMD x2 6000
2 gigs of patriot 800mhz duel channel ram
2 160g WD caviar 7200rpm sata 3.0g drives
1 DVD burner
1 DVD reader
and a poopy 7300gt
This is the PS I am thinking about getting
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
So because the 12v is lacking I think I should get a new PS and I've been looking on newegg and there is one that has 560 or so reviews and looks to be like a quality product. What do you think of it and do you have any other suggestions?? I don't really know much about PS or the good brands to stick to so any help would be much appreciated. Thanks for your help guys
My computer is a
AMD x2 6000
1 DVD burner
1 DVD reader
and a poopy 7300gt
