Hey everyone
Here's my problem
I just bought A 160GB HDD
and i connected as a slave hdd and it shows that has capacity of 127 GB.My master HDD is 80 GB and they are both IDE.They are from Excelstore.
If you are using Windows XP, you need to install at least SP2 to use partitions larger than 127GB.
Some older controlers also have this limitation, you might need to update the BIOS/Firmware +driver.
You might want to make sure you use NTFS and not FAT32.
Next time please include:
OS version (including SPs)
Motherboard model or computer model for laptops and OEMs
and the actual HD model, not just the mention of a 3rd tier manufacturer.
I see that revisions after V16 support "large drives" for the recovery tool but there is no risk in updating to the last revision... they must have got it right it hasn't changed since 2003!
Ok, this is old technology... AND uncommon brand names... cool. Anything else outstanding about this PC?
