I took a computer, a new case and parts to PC Club for a parts swap and new system build. The new case was an Antec solo with a black piano finish. The other case was my trusty Lian Li aluminum case. When I got home i discovered scratches in the top of the Solo Case in the bueatiful black piano finish. On the Lian Li case large steel scews had been screwed into the aluminum case where aluminum screws had been in an attempt to hide the fact that the case had been stripped out. When I removed the screws aluminum shavings fell on my desk. The USB ports on the front of the Lian Li case did not work. I did not receive the stock intel cooler, panels for the Antec case, or the special screws for the Antec Case. I contacted the store. They buffed out the top of the Solo case which only scratched the entire top of the case. I contacted corporate and was told by a regional manager that if the computer works then they are not responsible. I filled out a form to customer service and never received a response. I checked the BBB website and they have an unsatisfactory rating because they do not respond to complaints. Has anyone had a similar experience. If so what did they do?
