Tom's Hardware > Forum > CPU & Components > Sound Cards > Problem with onboard sound card
Forum CPU & Components : Sound Cards - Problem with onboard sound card
Hi I have just build a PC, I installed vista and my onboard sound card does not show up in device manager or when i try to install the driver. The sound chip is a c media 6501, this company provides minimal support and has even shut down registration to their forums. Has anyone got any ideas as to what the problem could be?
Thank you in advance.
Sponsored Links
No driver availiable for vista is my guess. Buy yourself a cheap PCI sound card, but before you do, research and make sure there are drivers availiable.
EDIT: sorry, did you get drivers and it cant be seen by windows? Either way, the above will fix it.
Message edited by yay on 01-13-2008 at 02:44:49 PM
Reply to yay
Have you checked at the manufacturer of the motherboard if there are Vista drivers?
Reply to PCD
Yeah there are vista driver that isnt the problem,, when installed keeps telling me to plug in the card...even though its an onboard, im so confused
Reply to eboni
Is the on-board enabled in the BIOS? Sounds like it is not even being recognized by the OS. Go into setup in your BIOS if you know how and try enabling the on-board sound device.
Reply to notherdude
I have made sure already the onboard sound is enabled in the bios, any other suggestions?
Reply to eboni
go to device manager, remove all devices remotely related to multimedia, then reboot. Works for me, maybe not so much you.
Reply to surrealdeal
Sounds good. And be sure there are not any yellow flags in device manager for devices without drivers. If nothing helps to get the OS to detect the card then try installing a copy of XP if you have one. If XP doesn't detect it either you might try updating your BIOS and if none of that works you may have a bad sound card chip.
Reply to notherdude
There are 1085 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
