Hey guys,
I have a problem with this drive... ( DataTraveler Secure Problem )
For people that are unfamiliar with this drive, it requires 2 mappings. F: for the password and G: for storage.
I am tech support for a big company. They have a network drive mapped to the G: which means that I must disable the drive to open up a slot for the storage of the USB.
Instead, I decided to simply remap the storage from G: to M: (Letter that wasn't used). Now, it works fine if you are Admin, but it will not work for someone who doesn't have admin rights..
Meaning, if I remove the Admin rights from the user ( I added them simply to change the drive letter ), the drive will stay on F: for password and M: for storage but I simply can't access the storage drive.
After looking up the website, it says that they must have consecutive letters.. That's false since i've done this procedure before..
I was simply wondering if anyone ran into this problem and found a solution to it.
Thanks.
EDIT: I know that I tend to cut corners in my explanations so feel free to ask questions.
Thanks.
