This is what I have so far. But I need a MB that will support vista as well as XP. and Pci 2.0 and 45NM processors
What do you think of the parts? anything Im missing or need?
only my second build in over ten years so im nervous about putting it together, any advice on the build process is also appreciated
you guys have been great
Video card: great deal, $339 W/crysis
http://www.newegg.com/Product/Prod [...] 6814130312
Ram Gskill 4gb, went with pc6400, 444-12 timings. dont see the need for any faster. $114 after rebate
http://www.newegg.com/Product/Prod [...] 6820231148
HDD-fastest seeek time on a 500gb drive, 32MB cache, and its perpindicular. $119
http://www.newegg.com/Product/Prod [...] 6822148288
fans:
http://www.newegg.com/Product/Prod [...] 6835185006
http://www.newegg.com/Product/Prod [...] 6835185004
2 1600RM fans and 4 800RPM fans. went for a mix of quiet and power. The case is a coolermaster stacker so the flow should be enough. if not Ill get more of the bigger fans
Paid 99 for the case in Dec
http://www.newegg.com/Product/Prod [...] 6811119122
http://www.newegg.com/Product/Prod [...] bCeramique thermal paste
for the cpu cooler Im going with a thermalright ultra 90- smaller than ultra 120 and just about as good, but not in stock so i cant finish my build
http://www.newegg.com/Product/Prod [...] 6835109127
PSU- spend the money on this, most important thing in your build
http://www.newegg.com/Product/Prod [...] 6817703009
DVD- got the samsung
http://www.newegg.com/Product/Prod [...] 6827151154
cpu-dont get OEM version, warranty only good for 90 days
But I still have a problem with motherboard- anyone have any othe ropinions.
I want 45NM support as well as pci 2.0. all for the future
fans:
