Help me build this monster!!
Last response: in Systems
OK I have these items ;
4 GB 4 x 1 GB PC2-6400 800 MHz DDR2 DIMM Memory Kit - Gold Edition
DP35DP Media Series Desktop LGA775 ATX Intel Processor Motherboard
Core2 Q6600 2.4 GHz Quad-Core Processor
e-GeForce 8800 GTS Superclocked 320 MB PCI-E Graphics Card
MX 3200 Cordless Laser Desktop Bundle
600 Watt StealthXStream Power Supply Unit
18X 8X DVD R +RW Internal IDE ATAPI IDVD18DLS DVD RW Drive
500 GB Caviar SE ATA-100 Internal Hard Drive
K so I hookup the cpu, CLICK* , the ram SNAP* , the monster sized video card CLUNK* , the 500 gb harddrive THUD*, the dvd burner POOSH*, and connect the Powe supply to the proper ports, I fire her up and she detects everything fine the first time then she doesnt wann load with all 4 gigs in so I take 2 gbs out and she loads fine but now she freezes in BIOS and when I try to instal windows, it just freezes, what could be the prob, thanks mates, she dected the cpu, harddrive and dvd drive and video just fine its just when I try to instal windows or just play around in BIOS, she freezes after a while and I have to restart, HELP ME OOO GOD!!
More about : build monster
Try resetting your CMOS the way your motherboard manual tells you. Also, make sure that your RAM is running at the correct voltages in the BIOS. It could be set at 1.8v, but your RAM may required 2.1v or something.
Other than that... unplug anything that isn't absolutely necessary for installing windows, and maybe even go down to one stick of RAM.
Related ressources
Check your CPU temperature, make sure it is reasonable. If your system came with the fan already installed it should have TIM between the CPU and fan so that should not be a problem but your CPU temp will tell you that.
Reset your cmos like rgeist said. If that does not get your system stable take your system down to the very minimum, one ram chip vid card and cpu. If your system works then start adding them back one piece at a time.
ok, the cpu thingy is not a issue because it has some paste on it and the freaking BIOS and system in general freezes everytime i look into it so i dont think i can change the ram voltage...
Is the board in the case?
Are there standoffs between the board and the case?
Have you tried all the ram one at a time?
Can you enter bios with the Disk drive and GPU unpluged?
Did you set Disk drive as 1st bood device in bios?
not in a case, how do I reset CMOS? I can try with one stick of ram..., yes ive tried with all the ram, no didnt set disk drive as first cause it freezes by the time I get there..
To reset the CMOS there is usually a red jumper on the board. It's like... a red rectangle and you'll see a set of 3 pins. It is covering two. Your motherboard should have a section about doing this, you'll just want to change the jumper to cover the two pins that represent a reset.
could the problem be that my PSU main connector isnt a 2x2 but a big one then a smaller 24 pin one I think? is not like two even connectors like shown in the motherboard picture? could this be it?
Try taking out all but 1 stick of RAM and access the BIOS. Set the RAM voltage to whatever it is supposed to be set at. If you don't know what it should be, post a link to the RAM that you have and we'll try to figure it out. I'm guessing that it's ~2.1V though.
rsetter1 said:
If you have a 2X12 (24 pin connector) disconnect the 2X2 (4 pin)
connector from it. It slides off. Plug the 2X2 in up there by the CPU
Huh? His motherboard has a 24 pin main power connection AND a 2x2 CPU power connection.
His power supply has a 20+4 pin connector, and ALL 24 pins should be plugged into the main power connection. The power supply also has a 4+4 connector... split that in half for the connection by the CPU.
-TyShoe
There is nothing wrong with the MB its your RAM. That MB will only work if you install 1.8v RAM, check the specs on the RAM that you purchased and if its not 1.8v then there is your problem.
good luck with the build
Matt
Yep, the 1.8v RAM is the issue with that MB. I built a PC over the holiday and ran into this exact same issue.
I had originally purchased this RAM http://www.newegg.com/product/product.asp?item=N82E16820227189 and got the same results as your when i installed it into my Intel DP35DP. I then looked through some more documentation online http://www.intel.com/support/motherboards/desktop/dp35dp/sb/CS-026645.htm and found that the DP35DP only works with 1.8v RAM. I then tried this RAM http://www.newegg.com/product/product.asp?item=N82E16820134117 and problem solved. PC booted right up and passed all benchmarks with flying colors.
Best of luck with your PC build.
Matt
I SALUTE YOU! I THANK GOD YOU WERE BORN! So whats ur pc specs with ur DP35DP?
i got q6600 2.4GHz 8 MB L2 cache
2 GB OF ram- just leme go to the store
8800 GTS 320MB
but u already know sniff*
the PC i built was a PC for my parents, they seem to only need a new one every 6 years or so.
Specs are below:
E6750 2.66ghz
Intel DP35DP
Kingston ValueRAM 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Seagate 320GB HD
Asus 8600GT Silent
LiteOn DVD-RW
Antec Sonata Plus 550 Case
ViewSonic VA2026W 20" LCD
Their big thing is PC noise so i went with the no fan graphics card and replaced the case fans with a Scythe S-FLEX SFF21F 120mm exhaust fan and a Scythe Minebea 92mm intake fan. Sitting right next to the Case its hard to hear the fans running, very nice!
Other than the mix up with the RAM and initially going with 2.1v OCZ RAM, the PC turned out to be amazing. Granted i was taking them from a P4 1.8ghz, 512 mhz RAM, 30GB HD and a 17" CRT to a C2D 2.66ghz FSB 1333 w/ 2GB of RAM, a 320GB HD and a 20" widescreen LCD, needless to say they liked it.
Remember to run Prime95 and a few memory checker programs to verify that all the pieces you purchased are working together correctly, especially if you overclock.
Best of luck with your new build.
Matt
Ask the community
