News
OCZ rolls out 600 watt modular power supply
Published on October 09, 2006
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
FSP Everest provides a Mountain of Power
Published on January 11, 2008
FSP displayed its latest high-amperage PC power supply, the semi-modular Everest Pro 1200. Read more
Thermaltake launches Purepower RX series power supplies with 140 mm fan
Published on January 04, 2007
Thermaltake Technology announced the launched of its new line of Purepower RX series ultra-low noise power supplies incorporating the ultra-silent 140 mm fan found on Thermaltake's high-end Toughpower Series power supplies. Read more
CeBIT 2008: Gigabyte Offers PSUs with up to 1.2 kW
Published on March 05, 2008
Gigabyte is expanding its line of power supplies into the Kilowatt range. The ODIN Pro and ODIN GT series now include models offering up to 1000 and 1200 Watts. Read more
Latest Reviews & Articles
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
SSDs Replacing HDDs Soon? Not A Chance
Published on December 29, 2008
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
System Builder Marathon: $625 Gaming PC
Unsurprisingly, hardware prices have dropped since our System Builder Marathon last month, which means we have access to more processing power at our same $625 entry-level price point for gamers. Come check out the configuration Paul put together! Read more
  Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Is there any disadvantage to power supplies with modular cables?
Word :   Username :
Bottom
Author
 Thread : Is there any disadvantage to power supplies with modular cables?
Profile: newbie
More Information
It seems like a new technology and selling point. Will non-modular cable PSUs be extinct soon?
I'm about to buy a replacement PSU for my current 430w one (need 600w+). Would it be dumb to buy a PSU with no modular cables? Higher cost isn't an issue, if in fact PSUs with modular cables are more expensive. I'm not even sure of that.
Related Product
Profile: enthusiast
More Information
As far as i know, the main reason for buying a modular power supply is so that you can selectively remove cables you don't need and thereby increase airflow in your case. So unless you are concerned about heat/airflow, then don't worry about buying a modular power supply. If the power supply you are considering is modular anyway, then go for it...they're virtually the same.
MSI P6N SLI Platinum || Q6600 B3 @ 3.0Ghz || EVGA 8800 GTX (625/1550/2020) || 4 gigs Mushkin Enhanced DDR2 800 (5-5-5-18) || 2xWD Raptors (200 gigs) 1x Seagate Barracuda (300 gigs) || HT Omega Striker Sound Card || Coolmax 700W Modular Power Supply
Fear God in life
Profile: nimble knuckle
More Information
I've not noticed any difference. I used an Antec True Power 500 in my wife's new system, it does not have modular cables. Then, I upgraded my power supply to get ready for the 3850 or 3870 cards with an Antec Neo 550 that is modular.
Whereas I'd heard horror stories years ago about modular power supplies improperly hooked up, I did not encounter any issues. There was no way to do it wrong and everything was clearly labled.
While I did not need the airflow at the time, I probably will in the future and I'm glad I went with the Neo, it's a tier 2 power supply, whereas the True Power was tier 3. The only thing I have to be careful of is to not lose the cables that I don't need right now!
I'd go modular again over just tying the spare cables together and trying to get them out of the way, as I'd done with every PSU prior to the Neo.
Oy, how could I have typed "does not have cables", corrected to "does not have modular cables".
Message edited by yipsl on 01-18-2008 at 05:41:47 PM
Profile: addict
More Information
When comparing apples to apples a modular PSU will be slightly less powerful because of the less efficient design. You can check Thermaltake's site for examples I know the 1000W and 1200W come if both flavors and the specs will show the differences. For me it's modular.
Profile: Faithful Poster
More Information
Profile: Forum Veteran
More Information
Take that with a grain of salt 'cause they manufacture PSUs. An independent source would be better.
Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | X1900XT 512MB | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi | WinXP
There is no such thing as a stupid question.
But there are stupid people.
Profile: Honorary Poster
More Information
OK, now that you have read the marketing hype, go to this link and get good info.
http://www.jonnyguru.com
More Information
If you are talking about low quality PSUs such as Ultra, who use the cheapest quality connectors, then PP&C would be correct. However, on the higher end with Antec, Corsair, etc., this is not the case. My SmartPower 2.0 voltages are at 3% or better which is well within the 5% ATX 2.0 spec.
I know what I know, and I don't know what I don't know.
Profile: enthusiast
More Information
Connectors are a primary failure point in electronic systems. Properly specified connectors in a quality PSU should be OK, but don't connect and disconnect them many times; cycling the connector wears out the contacts and increases the electrical resistance. Increased resistance means heat, and heat can destroy the connector - literally blackened circuit board kind of destruction. Hook it up once and leave it hooked up.
Perfect is almost good enough.
Profile: member
More Information
I was having a similar discussion in a different thread, and this article was pointed out to me:
http://www.motherboards.org/articl [...] 488_1.html
Well written with lots of hard data and little opinion.
Soooo.... short answer yes with an if, long answer no with a but.
Message edited by althius on 01-17-2008 at 03:08:14 AM
Profile: journeyman
More Information
I have an Ultra 500W X-Connect with modular cables and it has worked perfectly for the last 2+ years. I'm not sure why so many peoploe seem to knock them. Part of secret as with any piece of equipment is to make sure it is more than adequately sized for what you need rather than running on the ragged edge so if calculate you need 475W don't buy 500W - buy 600W or 700W.
Profile: enthusiast
More Information
I don't know why so many people knock them either!! I mean really, they're virtually identical to normal power supplies, just more (yet very limited) potential for user error.
Profile: addict
More Information
I don't know...maybe it's because some people see Ultra as the "no name" brand of computer technology, as they seem to have products in every category of computer stuff :p
http://i157.photobucket.com/albums/t62/theworminator/NBRSignature.png
Profile: addict
More Information
:bounce: Well Said. :bounce:
And absolutely correct.
I am old enough to be your grandfather.
It was born a Dell, it was made into a computer by StevieD
More Information
I've had the same PSU for about the same amount of time and it works great. I actually bought it to replace another Ultra which also worked great but had so many cables that it seriously was impacting air flow. Any ways the argument that the connecters on these modular PSUs cause such huge resistance seems non-sensical to me seeing as EVERY PSUs cables have to have at least 1 connector (the one that goes to the device). Nevermind the pass-through connectors seen commonly on fans which must cause much greater resistance when connecting another device through it. Once again I think this is just a lot of PSU over analyzing. Compaired to everything else in a computer the PSU is about as simple as it gets; Does it have enough watts? Amps? decent airflow? right connectors? then just make sure it's a good sturdy design and that's about all you have to care about.
GIGABYTE GA-P35-DS4 v2.0
Intel Core2 Q6600 @ 3.3Ghz
4GB OCZ Reaper DDR2 800 @ 915Mhz
EVGA 8800GTS 512MB G92
