Help me decide on a motherboard
I have read until my eyes are about to bug out of my head and I can't make a decision on the motherboard for my new gaming rig. I plan to do basic overclocking (nothing advanced or extreme) so I want something capable, reliable, and user friendly. I plan to start with a E6750 and move to a quad when I need to upgrade. I also plan to start with 1 8800GT graphics card. I would consider an SLi capable board if it meets the overclocking needs and fell under $150. In general, I am looking for the best value (price/performance). I do not need most of the bells and whistles on the high-end boards (like RAID, Firewire, etc.).
The three boards I have been considering are:
GIGABYTE GA-P35-DS3L
$99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
ASUS P5K-E/WIFI-AP
$139
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131196
Abit IP35-E
$115
http://www.directron.com/ip35e.html#caption (the only place I could find it today)
Please help we decide which one I should get.
(I will post this on the motherboard and overclocking forums but the homebuilt forum has been the most useful in my building research)
10 answers Last reply
More about help decide motherboard
  1. 1 vote DS3L.
  2. Asus P5K-E/WiFi-AP or else. :D
  3. i vote for DS3L
  4. For what it's worth?
    Just built my system before Christmas - have never had a problem with Gigabyte until this build. Tried 2 DS3L's, both bad. Would have exchanged for Asus, but wasn't in stock so went with EVGA. Gigabyte is a good board, I just thought after 2 tries I would go with a different brand.
    Good luck!
  5. DS3L - no RAID, no FireWire, no SLI/CrossFire
    Good overclocker: E6750 at 3.2 on OEM cooler with voltage reduction. Max OC on stock fan around 3.44 @ 65 C. Looking for 3.6, ZeroTherm BT90 on order.
    Get a well-ventilated case.
  6. CPU cooler to get when there back in stock.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835109125
  7. systemlord,
    Why is the cooler you listed better than the ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler? It is half the price with excellent reviews. Just wondering.
  8. they're
  9. I have a DS3L with a Q6600@3.42ghz. Easy board to OC. vdroop is a little much but livable. Price for a P35 board is great. None of the boards you listed will SLI you need a 680i or 780i board. TD had XFX and EVGA 680i boards with C2D and C2Q combos at a decent price a short time ago if you are set on SLI.
  10. bottomrungho said:
    systemlord,
    Its all about surface area, let my CPU cooler chart show you why. :D Trust me the Tuniq Tower 120 is much better.
    By systemlord at 2007-12-29
    By systemlord at 2007-11-13
Homebuilt Overclocking Motherboards Systems Product
