After days of thinking and thanks to your help guys. I've ended up with this system. Unfortunately, I can't buy from newegg.com so I had to use amazon.com instead.
I already explained I can't buy form newegg.com I don't have an American Credit card. I am very satisfied with amazon I just want to know if my system is good and whether I need to buy fans for my case?
you will find better deals than neweggs at pricegrabber.com. I usually save about $80 at pricegrabber.com when building high end systems. Im also luck that I live 1 block away from newegg warehouse, I dont have to order
online
online
Your orginal post said nothing about living abroad, but that's ok, I agree check pricegrabber. I've only done one build with a different gigabyte case, don't know about the fans, that is something you can do after you build. Good luck.
