Tom's Hardware > Forum > Homebuilt Systems > New System Build > which is the best power supply for my new build
Forum Homebuilt Systems : New System Build - which is the best power supply for my new build
ill be putting in a e6550, p35 ds3l, antec 900 case, 4 harddrives, and 2 optical drives
i cant decide between the
game x stream 600 w
http://www.clubit.com/product_deta [...] =CA6276601
corsair 520hx watt
http://www.clubit.com/product_deta [...] =CA6200026
enermax liberty 500 watt
http://www.clubit.com/product_deta [...] =CA6277816
their all tier 2 power supplies, but which one is the best, and do you think i need a modular designed one for my bottom mounting antec 900 case
thankyou for your help
Sponsored Links
Corsair HX520 is your best bet, it 40 amps combined on the +12v rails and is modular, which is very convenient for keeping cable mess down in your case.
Reply to Gravemind123
do you think ill need more then 520 watts with all that stuff hooked up?
Reply to monste4321
For an Antec 900 a modular power supply is almost necessary. It is fairly cramped and you will have no where to put the extra wires.
------------------------------ Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
Well, what type graphics card do you have? Those suck tons of power. You should be fine with the corsair as long as you don't have a GTX or something like that for GFX
Reply to doghills
The Corsair 520 would be fine even with an 8800 GTX.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
^Agreed. Its one of the best PSUs (Corsair 520HX)
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
ill be using either a 8800gt or 8800gts g92 if the price is right
Reply to monste4321
The 520HX is great and all you'll need
Yes this is true, with the system in my sig I am only using 350 watts via system calculator.>>>>> http://www.extreme.outervision.com [...] orlite.jsp
Message edited by systemlord on 01-07-2008 at 02:45:23 AM
------------------------------ Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
hmm well according to that thing i need 535 watts, you think a 520 will handle that? and maybe a future upgrade of a quad core will come once the price is right
Reply to monste4321
do powersupply prices ever really drop when new models or higher wattage ones come out, i mean the 620 hx is only 120, u think its worth it?
Reply to monste4321
Did you do it right. When I did your setup I got 345
i got lots of add-on cards and controllers
Reply to monste4321
n fans and other powerconsuming crap
Reply to monste4321
The power supply calculator in general goes over what you need. You should be fine with a 520W PSU, but if you think you might upgrade to something more power consuming in the future the HX620 would make sense.
I'd get the Silencer 610W from newegg. It's $127 including shipping and better than those 3.
Reply to aevm
The PCP&C Silencer is manufactured by SeaSonic, same as the Corsair HX series power supplies are. The Silencers are not modular, which can be a pain trying to hide cables.
Very true. But the pain will pass once you're done hiding the cables, and you get more juice for lots of "powerconsuming crap". :)
Edit: the 620HX gets great reviews too, but it's kind of expensive.
Message edited by aevm on 01-07-2008 at 05:41:08 AM
Reply to aevm
The Silencer actually has LESS power on the +12v, only by one amp, so you really aren't getting more power. Considering the internals are SeaSonic based in both, the Silencer doesn't really offer more other then being a few dollars cheaper(once you take the Corsair's rebate into account).
Always get more power than you require, because its better to have more power than you need than not to have enough power at all.
Reply to systemlord
well, ill be upgrading to a quad once the prices drop a lil so my consumption will go up and the hx620 is only 119 after rebate, not to bad if you ask me, plus its modular
Reply to monste4321
modular is great. It really helps in the Antec 900 with its limited space. I have 5 cables (CPU, 24 pin, PCI-E, SATA, molex) and theyre all hidden behind the case.
I could not imagine if you had all the cables coming out of it.
The HX's are great, and dead silent. If you can push the 620, why not. I got the 520 because it was $75 with rebate and too good to pass up.
Here's both corsair's; good deal
http://www.buy.com/prod/corsair-52 [...] 70716.html
http://www.buy.com/prod/corsair-62 [...] 70718.html
Message edited by chuckm on 01-07-2008 at 11:21:54 PM
Reply to chuckm
lol clubit has them for much less
Reply to monste4321
Add Clubit's $9 shipping charge and they are almost the same price, the 620 at Buy.com actually end's up $1 cheaper.
Reply to Delluser1
ill be ordering more then 1, building 2 identical comps, then you get cheaper shipping plus ill be ordering other stuff along with that
Reply to monste4321
they guarentee go stepping so im getting processors from them to
Reply to monste4321
does a 45 nm quad core use more or less wattage then a 65nm dual core? anyone know exactly how much the new ones use?
Reply to monste4321
Then you'll save some money, but it won't be "much less".
Reply to Delluser1
There are 702 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
