Tom's Hardware > Forum > Homebuilt Systems > New System Build > Ordered my new rig but questions regarding fans for a CM690 PC case
Forum Homebuilt Systems : New System Build - Ordered my new rig but questions regarding fans for a CM690 PC case
Hi guys,
I've just ordered my new PC from NCIX and I discovered afterward that the stock fans (2x120mm and 1x80mm) that come with my case (Coolermaster CM690) might be a little bit noisier than I thought. Here's the rig I'm talking about :
Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box
Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
Coolermaster CM 690 Mid Tower Black ATX Case 5X5.25 5X3.5INT No PS Front USB Sound Firewire & eSATA
Western Digital SE16 500GB SATA2 7200RPM 16MB Cache 8.9MS NCQ Hard Drive OEM 3YR MFR Warranty
Corsair VX550W 550W ATX 12V 41A 24PIN ATX Power Supply Active PFC 120MM Fan *IR-$15*
Palit GeForce 8800GT Sonic 650MHZ 512MB 1.9GHZ DDR3 PCI-E 2XDVI-I HDCP HDTV Out Video Card
Noctua NH-U12P LGA775 AM2 Heatsink Heatpipe Cooler W/ NF-S12P 120MM Fan -12.6-19.8DBA
Crucial Ballistix PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-12 240PIN Dual Channel Memory Kit
Since I want to overclock but still have a somewhat "not too noisy" PC I wanna modify my order to get 4-5 of these instead :
http://www.ncix.com/products/index [...] ate%20Loon
I've heard only good things from these fans on many websites, what do you guys think ?
But my main concern is, will I be able to adjust the fan speed with a software such as speedfan or some other software ? (I don't know much about fans, as you can see). Or do I need to have fans with a temp sensor to be able to do that ?
Also, any opinions regarding the replacement of the side fan (80mm) would be appreciated. Which good but silent 80mm fan would you choose from ncix ??
Thanks !!! :)
Sponsored Links
3 thumbs up on the selection!
Yes, I think you can adjust the fan speeds somewhat with bios or speedfan since the Yate Loon fans have the 3rd yellow wire which controls speed. Plus them in the mobo.
Personally, I'd pick up a $20 fan controller so that I can adjust the fan speeds anytime.
Reply to akhilles
Wow a lot like my system I just built.
------------------------------ Q6600 G0 @3.6 1.34v | GTX280 1GB | 26" Samsung T260| 19" 1907FP | Asus Maximus Formula X38 (Rampage Mod) | Kandalf VD4000 LCS | Ultra X2 750W | Supreme FXII 7.1 | Audio FX Pro 5.1 Headset | 4x1024 Ballistix Tracer 5-5-5-14 1066mhz | LG GGW-H20L
Reply to thecompukid
the mobo has only two header that can control fan speeds. one for CPU. other for extra one. so what im saying is. u probably need a fan controller for that.
------------------------------ Q6600 @ 3Ghz | zalman 9700NT cooler | gigabyte P35-DS3L | Kingstone DDR2 667 2GB x 2 | HIS 4850HD with Accelero S1 Rev.2 | enermax Liberty 500w | Coolermaster C5 case |
Reply to night_wolf_in
Hmmm my case came with only 120mm fans. Thats odd yours came with an 80mm. I would use 120mm fans also on the side. They work awesome for my setup. The side panel supports them so definitely use them.
Message edited by thecompukid on 01-07-2008 at 04:59:22 PM
- 0 +
Take a deep breath. And hold it. Don't jump in to fix a problem you might not actually have.
Why not wait till you get the case and then test out for yourself if the CM 690 fans are actually too loud.
The CM website says the case fans are rated @ 21dBA and thats really quite good. CM 690 website
The Yate Loons you picked out are 24dBA.
[:wr2:2] No where does it say that case comes with an 80mm fan.
The only 80mm fan mount the CM 690 has is on the back side of the motherboard tray under where the CPU will be on the motherboard - and that only takes an especially thin 80mm fan.
http://images10.newegg.com/NeweggImage/productimage/11-119-137-12.jpg
And finally those Yate Loon fans @ $9.99CAD are also available from Direct Canada for $5.62
[:wr2:5] OK, you can let your breath out now.
Message edited by WR2 on 01-07-2008 at 06:38:47 PM
Reply to WR2
FYI, you can do awesome cable management in this case. I am very happy with it. I will post some pics when i get home from work tonight.
- 0 +
Your case has LOTS of fan options including spaces for 140mm fans (1x side panel and 2x top of case).
It should arrive out of the box with 3x 120mm fans, 1 front, 1 rear and 1 side panel. Thats probably enough cooling to set up and test your system (including over clock testing) to measure the temps and figure out (1) if you need extra cooling and (2) where and what type of fans you want to keep your stuff cooled down, and still quiet.
Your GA-P35-DS3L has 4 x fan headers. Two are 4 pin and two are 3 pin. You have a 4 pin for your CPU heat sink fan and one other fan of your choice.
Message edited by WR2 on 01-07-2008 at 06:37:42 PM
Reply to WR2
- 0 +
You guys are totally right, it comes with 3x120mm and not 2x120mm + 1x80mm (Even tought there's a 80mm fan slot on the side panel for the MB). (btw the case/PC is ordered but I haven't received it yet)
akhilles : Thanks for the thumbs up :D
WR2 : I've read on many forums that CM690 owners all think the stock fans s***k in this case (even if the case in itself is great). Not only do 90% of the owners think they're noisy, it seems they don't push that much air either :??:
That's why most of them change them for yate loons since they're more efficient.
Don't worry about the price, I asked for a pricematch when I added the fans to my order, I did my homework and I knew they were cheaper on directcanada :D
Concerning the fan controller, I think I'll wait until I have the PC just to see how loud it is with all the fans at full speed. If it's too loud I might buy one, I'll see.
I just hope my modifications on my order will be processed before they build/ship my PC.
I ordered 7 of those fans !! Better have more than not enough ;)
The airflow is definitely gonna be good lol
Thanks for the advices !
Reply to Rimsta
There are 926 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
