Strange problem needs brainstorming!!
Okay guys, I have a pretty strange problem for you! I have two recently built systems, first the specs:
Note: Parts in bold are the same on each system
My comp:
Q6600
GA-P35-DS3L
2 GB Crucial Tracer Memory
BenQ 19"
MSI Geforce 8600GT
Windows Vista 32 Bit
PC Power and Cooling 610 Watt PS
Folks comp:
E4500
GA-P35-DS3L
2GB Crucial Ballistix Tracer Memory
BenQ 19"
EVGA Geforce 8800GT
Antec Earthwatts 430 Watt PS
Now to the problem. I have two different cases for these builds. When I plug in headphones OR USB to the front panel on either system, 50% of the time, my monitor will just lose the signal. I noticed it on my computer first, however after gutting it and rebuilding thinking it was a short, it still happens.
Then, after plugging a camera into my folks system, the same thing happened! Now the ports do work and like I said 50% of the time, this problem will not happen, 50% it will.
I narrowed it to either the chipset drivers or the vista drivers but I really am not 100%. Any thoughts?
My comp:
Q6600
GA-P35-DS3L
BenQ 19"
MSI Geforce 8600GT
Folks comp:
E4500
GA-P35-DS3L
BenQ 19"
EVGA Geforce 8800GT
More about : strange problem brainstorming
i had some issues on one of my motherboards with bad grounding, you would literally get a shock if you touched the case and the usb cable at the same time.
my guexss would be an electrical issue, not software related. double check you've got some metal screws in between the motherboard and your case, double check you've got a grounded plug, double check you're plugging into a grounded socket.
good luck
good luck
It's not static, I ground myself before plugging anything in and I feel no shock. This is happening on two separate systems with similar hardware too. The case connectors have a 4 pin + 1 ground which are hooked up correctly. I did gut one system in case it was a short, but to no avail.
For example, I touch the metal case and I get no shock, then I plug i in. I really think it is a driver issue but not sure if it is vista or the chipset...
Related ressources
- Dedicated HTPC build, $600ish, brainstorming - Forum
- Click of death, brainstorming a solution - Forum
- Home Server, With a Twist ( Brainstorming ) - Forum
- 7970CF Low Usage, Low FPS. - Forum
- Water-cooling Build Log: Project Red-Chalk - Forum
On two different machines that otherwise work, it is unlikely to be a hardware fault.
I suspect a problem in connecting the front panel headers. Question your assumptions about the polarity of the connectors. If the usb devices do not cause a problem when connected to the rear mobo usb ports, that is more evidence of a front panel connector problem.
Some cases have been known to ship with miswired connectors, or incorrect documentation.
I did try toying with the connectors, but they only work one way. It is setup like this
usb_2 usb_1
grounds are the non-bold. The other is a 4 pin connector that only works one way. I'm not sure what happens if I connect the 4 pin to the top instead of the bottom but both of the case connectors are 4 pin+1 ground.
Like I mentioned, this worked fine with the same case and an asus A8N5X chipset.
usb_2 usb_1
meadowlands what those system properties device manager say.also you have two connector on mobo (hd ) and (ac97) you could try other one that you haven't tryed yet.sense it's happening on both ga p35 ds3l mobo ,I would think that is likely the problem,not that the boards are bad .also check manual page 28? it just sounds like a cable in wrong place.hope this helps
meadowlands http://www.directron.com/installusb.html#caption try this place see if it helps.
also did you check usb controller in device mgr.
Ok, from what I can see, I have two of the 4 joined pins +1 extra ground. On the mother board the USB's are laid out like this:
97531
108642
I have the 4 joined connected to 8642 and the extra to 10. Both ports do work in this setup, so I am assuming it is correct or should I not have that extra ground hooked up?
97531
108642
meadowlands have tried loading xp sp2 on either of the pc ?
also when you say the monitor loses signal the light on monitor goes yellow!how do you get a signal back,by reboot or turn monitor off and then on.and also it only happens when you hook usb device.if you plug up usb devices first before booting up does this happen.
I had a similar problem with my system. Even though I couldn't feel it, it turned out to be static-induced, but proper case grounding would likely have prevented it. Rebuilding my system (all same parts) in a different case completely resolved it. Even though you have two different cases, if they are cheap and/or cheesy, this could still be the problem.
Related ressources:
- ForumGA-P35-DS3L (rev 2.0) and Intel Q9550 Problems
- ForumTransfer rates between internal drives REALLY slow
- ForumNO POST
- ForumBad L2 Cache?
- ForumWhat features do you want in a Cyberpunk RL?
- ForumWhat does life & work mean to you?
- ForumCombat Logic
- ForumGT300 NEWS
- ForumNew HIS HD7850 2 gb.having very strange kind of display problem ..
- ForumStrange problem : System not booting up
- ForumBest mobo capable of multi-tasking
- ForumASUS P5AD2 Deluxe DVD ROM Problem!! HELP!!!!!
- ForumA8N SLI needs video card
- ForumP5E-VM HDMI problem (BSOD)
- ForumECS P4M900T-M with installation problem of GEforce 8800GS
- More resources
Read discussions in other Motherboards categories
