Hey all i have just purchased some new hardware but because i'm a total nub i don't really know if everything is compatible. maybe someone in the know could look it over and let me know if i made a mistake somewhere. thank you kindly!
Mobo: ASUS P5N-T Deluxe LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
Video: EVGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported
RAM: Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Links:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131247
http://www.newegg.com/Product/Product.asp?Item=N82E16819115017
http://www.newegg.com/Product/Product.asp?Item=N82E16814130072
http://www.newegg.com/Product/Product.asp?Item=N82E16820146565
so, do you think i should have gone with a PCIe 2.0 video card? Should i have chosen different RAM? I looked all over ASUS dot COM, and i couldn't find any RAM recommendations for the P5N-T. most of the information i read doesn't make sense to me yet. This is my first build! Any recommendations you have are welcomed! Thank you again!!!
Links:
