Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Do I have problems with my card?
Forum Graphic & Displays : Graphics Cards - Do I have problems with my card?
So I overclocked my XFX 8800gt alpha dog edition to around 700/1700/1900, which from what I've read is quite modest. I am using stock cooling though, just turned up really high. However, I downloaded CoD4 off of steam and it's starting to freeze a lot after a while, it just freezes and stops responding, and the screen may turn a different shade of color, one time white snowy stuff seemed to cover the image, which I guess is artifacting? However, I ran a lot of stability tests afterwards, and no problems came up. During testing temperatures can go up to 80 degrees, but while I'm playing cod, the temperature pretty much never goes above 70. I'm using 3dmark as well as the fur rendering program. Is this a problem with the card, or is it a problem with cod on steam? I'm not really sure.
Sponsored Links
I think it's temps. Even though your GPU chip is saying 70, your Mem and Mosfet temps can be too high. Try to run it with the fan at 100% using RivaTuner and see if you get the artifacts. Before I even OC'd my 8800GT I bought a aftermarket cooler. I'm at 730/1834/958 and never ever had any artifacts, my GPU has never got above 53C. Ohh HR03 GT is my cooler.
Reply to Conumdrum
Oh I see, is installing an aftermarket cooler hard? I'm still kind of learning the ropes. the fan is already set at 95% because at 100 it instantly gets a lot louder for some reason.
Also, this is kind of an unrelated question about fans- I have an intake fan in the front, a fan in the back, a fan in my psu that moves a lottt of air, and a side fan, its front-in, back-out, which i guess is pretty obvious, but what should i do with the side fan? it came blowing in, but doesn't that defeat the purpose of the cpu fan if the hot air can't get out?
Reply to xinsomniacboix
No matter how you set up the fans, you want to circulate as much air as possible. If you are blowing cool air in, hot air is going out somewhere else.
If you are blowing hot air out, cool air is coming in somewhere else. Make sense?
Reply to rallyimprezive
Yeah, that makes sense, but is one better than the other?
Naw, just try to figure out a way to move as much volume as possible.
And try to get a "breeze" going. Imagine how the air is flowing through the case, and try to set up the fans to move air in one direction.
Also, keep in mind that hot air rises.
ok, thanks for the tips =)
you bet!
Oh and keep out the dust bunnies. They act like an insulator and can heat things up pretty quick.
There are 1205 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
