Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Thermaltake TMG ND5 vs. DuOrb cooling fan
Forum Graphic & Displays : Graphics Cards - Thermaltake TMG ND5 vs. DuOrb cooling fan
Hello
I just ordered a Galaxy GeForce 8800GT 600MHZ 512mb and I found out it has cooling problems.
I am considering replacing the cooling fan with either a Thermaltake TMG ND5 or a Thermaltake DuOrb. I curious to know what people know about the two fans? Or perhaps people have a better suggestion to cool a GeForce 8800 GT?
If it helps, my case in an Antec Sonata II and there are only exhaust fans in front and in the rear.
Thanks
Sponsored Links
stick with evga, bfg and leadtek
then xfx and msi
watch out for gigabyte and off brands
its not the cooling its could be other things there ram issues and pcb problems too. if its cooling then take your door off and put a fan pointed at the card - does it work better and longer?
if not - send the card back - send the card back and get an evga or msi
------------------------------ http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Reply to dragonsprayer
- 0 +
If you don't want to send the card back, your best cooling options are the Thermalright HR-03GT or the Artic Cooling Accelero. You could use them in a passive way, or add fans onto the one one you'll choose.
I wouldn't go with Thermaltake, the DuoOrb may be a good cooler, but it will be far more noisier than the 2 I had suggested you.
Here's some reviews:
http://www.abchw.com/content/vga-h [...] er-roundup
http://enthusiast.hardocp.com/arti [...] VzaWFzdA==
I personally own a Thermaltake case and had a few Thermaltake products. The case is good, but the fan are noisier than they tell. The only real good fan I owned from them is the Big Typhoon and the Extreme Spirit II, the 3 others were not so good.
------------------------------ Q6600 G0, Asus P5Q-E, 4GB PC6400 OCZ Reaper HPC, EVGA 8800GT 512MB Superclocked, SoundBlaster X-Fi Xtreme,1x Vraptor, 2x WD 320 GB RAID 1, Enermax Liberty 620W, Thermalright Ultra-120 Black
Reply to poup23
- 0 +
I just bought a Thermalright HR-03GT with a ZM-FM2BL fan from Zalman to put on. I'm waiting to receive them shortly. All Zalman products are great and extremely silent. You should consider them before Thermaltake.
Reply to poup23
Who cares ... it has a warranty dont it?
Unless your worried about it increasing your internal case temps (for overclocking) i wouldn't worry.
------------------------------ Thermaltake Armour LCS | Thermaltake Toughpower 750W | Gigabyte GA-P35-DS4 (Rev 1.1) | Intel Core 2 Duo E6750 (@3.2Ghz) | Leadtek 8800GTS OC 320MB | 4x1GB Corsair XMS2 4-4-4-12 | WD 320GB SATAII HDD
Reply to daleyboy
- 0 +
I have TT DuOrb. It's nice, cool down my idle temp from 59 to 43 and full load from 75 to 54 max. It comes with memory and vram heatsink so I don't need to worry about it (don't like others brands that doesn't includes mem/vram heatsink). Also, I can't notice or hear any noise from the fans, it's pretty silent and has a good looking blue led fan. All and all it's a good product to take into account imo.
http://i268.photobucket.com/albums/jj28/Liswara/8800GTDuOrb.jpg
Reply to liswara
Helllo
Thanks for all your responses.
I did take Accelero into consideration, but they were all sold out. So I eneded up getting the DuOrb. It seems like the easiest to install and it came with all the memory and vram heatsink needed (as mentioned above).
Thanks again
Reply to loafing_smurf
Helllo
Thanks again
I'm thinking of getting one for my 9800GT. What are your idle and load temp with DuoOrb ?
Reply to Kingsface
There are 482 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
