"No links, I got these pics in person at Mushkin's shop in Denver today. Brian Flood showed me the guts of the new 800 watt unit. The supply is built to spec for Mushkin by Topower and is conservatively rated. Brian has used it to power a triple SLI rig that ran at over 800 watts load for extended periods of benching and gaming. The unit can run multi-rail or you can flip a switch that runs it in single-rail mode for demanding applications. The fan is 13.5cm and at load it can deliver a very healthy airflow. The unit is relatively light and has a nice pair of aluminum heatsinks. The build quality looks to be excellent and the parts are well laid out. The ripple at load is 37mV on the 12V rail."
