I recently bought a hp dx2250 for a bargain price of £185.00 after the £50.00 cashback from HP. This to replace my ageing agp Shuttle xpc sng5v3
AMD Athlon X2 5000+ Processor
2GB Memory
250GB Hard drive
DVD-RW Optical Drive
Gigabit Ethernet
Vista Home Basic Operating System
The standard power supply is lite on 250w.
I decided to buy a pcie HIS Radeon 3850 HD, i had read they were low on power consumption. Fitted fine but i wasn't a little dissapointed in benchmark results in 3dmark06 etc.
I ran the call of duty 4 demo fine looked great no crashes.
I installed amd power monitor and noticed the core frequencies fluctuate betweem 1000mhz and 2400mhz, the voltage does too between 1.1v and 1.5v.
Following on i installed CPU-Z and again the core speed, multiplexer and bus speed fluctuate rapidly.
Is this normal behaviour or is it a sign that the power supply is struggling ? I did use the online power supply calculator and based on the hardware 1dvdrw, 1hd, cpu, video card it should be sufficent.
Is there a good game demo to show fps and expected fps based on the graphics card being used ?
Its completely normal. What you're witnessing is computer trying to lower the power consumption when you're not using it. By throttling the core speed as well as voltage, computer can reduce power consumption.
This is called Cool n' Quiet.
------------------------------Intel will not take the top spot, or probably the top 3 spot back for the forseeable future. Not even with 32nm and more cores will intel be able to beat Jaguar. - JennyH the AMDiot, Nov 2009
Reply to yomamafor1
Agreed with above, the behavior you see is normal and just trying to save you some cash on the electricity bill.
Your PSU is a bit close to the limit, true. TBH I am surprised it handled even the HD 3850. If you want to add hard disks or other things later you should consider replacing the PSU at that time. I had great success with OCZ StealthXStream 600W. It actually fit in an HP box (a 520HX or Silencer 610W wouldn't fit, for example). This may depend on the PC model, so measure your current PSU and make sure whatever you buy to replace it is the same size.
