Tom's Hardware > Forum > Storage > Hard Disks > Serial ATA PCI Controller Card Problems
Forum Storage : Hard Disks - Serial ATA PCI Controller Card Problems
I've got an old HP computer with an EIDE hard drive. I'd like to upgrade the EIDE hard drive to SATA. The computer currently runs on Windows 2000. I purchased a SIIG, Inc Serial ATA PCI controller board. I installed the driver and it shows as being successfully installed and working fine.
The manual says the controller cards BIOS will appear every time the system starts up and indicate the devices attached to it. The controller cards BIOS doesn't appear no matter what PCI slot I plug the card into!
Is there something I need to disable or change in the HP BIOS to make the new Serial ATA PCI Controller card BIOS show up?
Sponsored Links
How old is the computer? Its possible that it won't boot off a pci device.
Reply to sturm
look for an option in the hp bios called scan option roms or similar, and make sure its enabled. that will force the bios to execute the code found in the controllers bios, therefore enabling it fully
Reply to michiganteddybear
I like to know where I should set the following HP BIOS settings to support this new controller board:
1. PnP-OS:
Selects whether BIOS or Plug And Play system (Windows) configures non-bootable devices. This also affects integrated devices that are set as [Auto]. What setting should I use?
2. Reset Data:
[Select Yes if you want to clear system configuration data]
Should I select Yes or No?
3. PCI Device Slot 1:
Option ROM Scan -> Initializes device expansion ROM. Enable this option if the device is used to boot the operating system. Based on what is posted above I think this needs to be enabled.
4. Bus Master:
Enable this option if you need the BIOS to set the PCI Bus Master bit. This could be necessary for some older PCI accessory boards. Should I enable this option?
5. Bus Latency Timer:
What do Aoh, Coh, Eoh, F8h mean?
6. High Priority:
This option maybe used in order to set a higher priority for this PCI slot. Should I set this to enable or disabled?
7. Quickboot Mode:
Allows the system to skip certain tests while booting. This will decrease the time needed to boot the system. Should I set this to enabled or disabled?
8. Boot Device Priority:
Will the new SIG II Serial ATA PCI controller board ever show up here?
9. Integrated Bus IDE Adaptor:
What setting should I use... Primary Only, Secondary Only, Both Enable, Both Disable?
Reply to Neil Jones
- 1 +
1: Yes (for Windows)
2) Don't know, (I'd guess no)
3) Yes (make sure your card is in slot 1)
4) Probably not
5) Hex values, try A0h first
6) Probably yes
7) Probably yes
8) If it's configured, probably (should appear as a SCSII device); you might need to power-cycle (after configuring) for the device to appear in the list.
9) These are the on-board IDE channels, leave them enabled; disabling empty channels will (slightly) reduce boot time (turns off device detection) but will prove to be a PItA when you forget they have been disabled.
If this doesn't work, try posting a PC/MoBo model number and see if anyone has access to a BIOS manual.
Reply to MrLinux
No matter what changes I make I can't get the SIIG, Inc Serial ATA PCI controller board BIOS to show up like they claim it should in their manual.
"The Serial ATA PCI BIOS will appear everytime your system starts up. If the BIOS doesn't show, please install your controller in another PCI slot. During this (Post) process, the bios will show up and indicate the devices attached to it."
I set the HP BIOS to try and boot Windows XP Pro which is installed on this drive and it tries but fails. When I don't boot from the drive with Windows XP on it I can see it. It shows up as a "removable drive".
No luck calling SIIG as they say they are on vacation till after the 4th.
Reply to Neil Jones
How do you know if you can boot off a PCI device without experimenting / trial and error?
Reply to Neil Jones
- 1 +
Haven't yet seen a PC with PCI that couldn't boot via a PCI card, there *may* be a restriction on which PCI slot(s) support booting or restrictions due to shared resources (DMA channels, IRQ's etc);
booting from and expansion card has been pretty fundamental since the days of ISA slots.
Some form of technical manual for the PC/MotherBoard would certainly help.
Reply to MrLinux
Don't have a manual. The computer was purchased used from where my wife use to work. How can I make it boot from a PCI card? Can I disable something? I should be able to use a hard drive with XP Pro on it that runs in another machine right? Where can I read up on DMA channels, IRQ's because I don't know what they are.
Reply to Neil Jones
- 1 +
The short answer is to find the model number of the PC or Motherboard and either post it here or Google it.
If the copy of XP was installed on another PC, you probably would have problems, it would have installed the required drivers for the original hardware; XP really needs to be installed on that PC.
Reply to MrLinux
It's an HP Vectra VL420 MT. System number P5756T.
Okay on my other hard drive with Windows XP not working. I will get a new hard drive but before I do that I would like to see the BIOS for this PCI to SATA controller card show up like the manual for controller card says it should.
Reply to Neil Jones
- 1 +
This machine comes in 3 forms, Small Form Factor, Desk Top or Tower; You need to confirm the hardware build you have there, is the existing HD IDE or SCSII? Are there any existing PCI cards fitted?
HP manuals:
http://h20000.www2.hp.com/bizsuppo [...] en&cc=uk#1
Upgrade manual:
http://bizsupport1.austin.hp.com/b [...] v06564.pdf
Reply to MrLinux
It's a tower. The existing HD is IDE. There are no PCI cards fitted... all three PCI slots are empty.
Maybe I should give up on this card and try this ->
http://www.cooldrives.com/sahadradtoid.html
Or try a more expensive solution that I can later use in another computer because now I'm pissed and want to boot from a PCI slot ;> ) ->
http://www.promise.com/product/pro [...] uct_id=165
I've reviewed all the manuals from the link you posted and found a spec for the HP Vectra Tower PCI bus.
"PCI Bus Interface
• Supports PCI at 33 MHz
• Supports PCI Rev 2.2 Specification
• 133 MB/sec maximum throughput"
The Promise card has a 66 MHz PCI bus. Will a 66 MHz PCI bus controller card work on the HP Vectra 33 MHz PCI bus?
Message edited by Neil Jones on 01-03-2009 at 03:11:15 PM
Reply to Neil Jones
There are 1083 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
