I Was wondering do i need a new power supply.
Right now i have the antec true blue 480w.
it is
+3.3V +5V +12V +12V2 +5V SB -12V
30.0A* 38A* 18A* 18A 2.0A 1.0A
my system as of right now is.
ANTEC 900 case
5 120mm fans
1 200mm
q6600 oc to 3.3ghz 1.35 voltage
2 sata hard drives
1 8800gt 512mb
x-fi gamer sound card
1 dvd burner drive.
2 sticks of 2gb ram
So does my system need more power then the antec true blue has to offer.
If not i was thinkngi about getting the ULTRA Lifetime Series Pro 750-Watt.
Reason i would get it is because it has a lifetime warrenty and its 85 dolalrs with a 40 dollar rebate.
Also i was plannnig to use my evga step up for ethier the gx2 or the gtx which ever is out is the step it up time frame. Which ends april 2nd. So i know if i went gx2 my antec wouldnt be able to handle all that..
The ultra is 750w
+5V +3.3V +12V -12V +5VSB
32A 28A 45A 0.6A 2A
it is
ANTEC 900 case
5 120mm fans
1 200mm
2 sata hard drives
1 8800gt 512mb
1 dvd burner drive.
2 sticks of 2gb ram
The ultra is 750w
32A 28A 45A 0.6A 2A
