Before i begin, I'm not totally new to building computers, all but the very first one i owned have been build from scratch by me and my brother, but i have never built such a powerful, or expensive, system!
I am buying the components entirely from Overclockers as i have used them a lot before, i trust them and also partially because I'm too impatient to wait for the parts to come from all different places!
Ok, here goes:
Intel Core 2 Quad Pro Q6600 http://www.overclockers.co.uk/showproduct.php?prodid=CP-161-IN
2Gb DDR 2 RAM (will get another 2Gb when i can afford it!) http://www.overclockers.co.uk/showproduct.php?prodid=MY-013-OK
Hiper 680w HPU-5K680 PSU http://www.overclockers.co.uk/showproduct.php?prodid=CA-021-HP&groupid=701&catid=123&subcat=461
Twin ATI Radeon HD 3870 XT http://www.overclockers.co.uk/showproduct.php?prodid=GX-078-OK&groupid=701&catid=56&subcat=416
Gigabyte GA-X38-DS4 mobo http://www.overclockers.co.uk/showproduct.php?prodid=MB-110-GI&groupid=701&catid=5&subcat=946
XClio Propeller http://www.overclockers.co.uk/showproduct.php?prodid=CA-022-OK
As you can see, it has been built to a price, £800 was my total limit and this is just £775 with delivery so is perfect! Basically, will all of this work together? My main concern is the motherboard as i found it hard to find a DDR2 one which had twin 16x PCI-E slots instead of the 'fake' 16x and 4x setup a lot seem to have!
Any suggestions are welcome, but i cant really afford to spend much more on any of the components.
Thanks a lot,
Rich
UPDATE: With the suggestion of a slightly better motherboard which costs a little more, i was looking at the PSU i am getting, for about £20 less i can get this one, http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-HP&groupid=701&catid=123&subcat=461. Its only 50W less than the other so it will still be fine with that setup right?
Ok, here goes:
Thanks a lot,
Rich
