A friend of mine is going to be sending me a pair of 500 gig SATA drives for essentially free, which has prompted me to start looking into building a new PC (replacing my P4-3GHz system). My primary applications are games, with some office work/writing/etc. Please take a look at this list:
ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
PC Power & Cooling Silencer 750 Quad (Crossfire Edition) EPS12V 750W Power Supply 100 - 240 V UL,
CE, CB, RoHS
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341011
LIAN LI PC-60BPLUSII W Black Aluminum ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112116
EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI
Supported Video Card (with intent to purchase a 2nd one at some point for SLI)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130312
PHILIPS 2-Tone 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X
CD-R 24X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe
http://www.newegg.com/Product/Product.aspx?Item=N82E16827248011
Am I missing anything? Do I need custom cooling or will the stock CPU cooler suffice? Anything on this list
not compatible or known to be poor quality? Do I need a flash-memory/media reader (going to assume that floppies
aren't needed at this point). Also, are people currently moving to Vista at this point? I'm thinking Vista for DX10, but a couple of my RL friend say that DX10 currently isn't that big a deal and that Vista's still got some performance problems. I'm leery though about getting XP, then being forced to upgrade the OS yet again in the immediate future, so I was thinking about just jumping forward so that the system would be good for the long-term.
CE, CB, RoHS
