Antec 900 Fans help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Antec 900 Fans help
My apologies if I posted this in the wrong section.
I recently just built and put together a new computer and one of them is the Antec 900 Case. Windows XP seems to be working fine when I turn it on. Only problem is, the fans on the 900 case aren't working. The one on the CPU and power supply are fine. I came to notice on my new Asus motherboard that there are a CHA_FAN 1, PWR_FAN and CPU_FAN connectors. The cpu fan connector is connected, but I don't see any for the other ones. Is that why the fans aren't turned on because they are not connected? I also assume the blue led lights go on when the are on, but they aren't. I thought the cables would of came with the motherboard or the case? I can't seem to find them and its the one with the 3 pins. I've been digging around in the case and cable management sucks....I only I can find are the 4 pin connectors which aren't connected to anythihg. I doubt that works though. Anybody that owns a 900 knows if I have to go out and buy some or should they be included somewhere??? Some help please :) and thanks!
Sponsored Links
Quote :
....I only I can find are the 4 pin connectors which aren't connected to anythihg...
You connect the 4-pin fan connectors to the PSU molex leads.
Reply to rgeist554
- 0 +
Molex leads? I read brieftly about it in the manual, but I also can't seem to find what they connect to. One of them is labled audio. I assume there are some cables in the case that I don't have to use? Are you sure they have something to do with the fan?
Reply to darrenz
- 0 +
I didn't have this problem on my 900...it was fairly obvious which cables were the fan power cables. There should be one for each fan, make sure they are each plugged in.
Don't know what else to tell you.
Reply to gryphyn
- 0 +
yeah, i think its the 3 pin connectors. I can't find them anywhere. Should they be included with the case or motherboard?? I might have to dig deeper and see if they are in any boxes when I bought my computer. I don't want to take it to the shop to have it checked out.
Reply to darrenz
Quote :
This is the way I feel. >.>
Ok these things:
http://upload.wikimedia.org/wikipe [...] nector.jpg
Hook up to the black connectors on the inside the case
Reply to rgeist554
- 0 +
I have a 900 case. You plug the black 4 pin molex connnector right to the power supply. These cables are hard wired to the fan (all fans have the wires attached) You don't connect these to the motherboard. You can even chain a few of the fans together because they don't draw that much power. I put the top and back fans on one lead and the front case fans on another lead. There should also be a little Low/Medium/High power switch that controls the speed of each fan.
Reply to kansur0
Its a great case. Dont get fooled into using the air duct. Run a fan on the door for good measure. Like stated above all case fans on the Antec 900 are hooked into the PSU not the MB. Enjoy the case I know I am.
Reply to jerseygamer
http://img411.imageshack.us/img411/6456/029ln7.jpg
My baby. Spray painted the inside back and fitted all green fans. Love it so much.
Reply to Obi-Wan-Shinobi
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Antec 900 Fans help
There are 1221 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
