Did a search and nothing came up...
Just put a new build together and I'm getting a blue screen when installing XP Pro 32.
My system:
e6750
Abit IP35 Pro
2 x 1GB crucial ballistix PC6400
WD 500gb
evga 8800gt
samsung DVDRW
zalman 9700
antec 900
OCZ gamexstream 600w
The error:
Windows CD boots and begins to install. Asks where to format and install and it gives me one partition with much less than what I would expect for the hard drive... something around 131000 MB. I choose that location and it begins to format. As soon as the format reaches 100% I get a blue screen "A problem has been detected..." The technical information is as follows:
*** STOP: 0X00000024 (.... bunch of characters ...)
*** ntfs.sys - Address F70ECBA9 base at F7OAAOOO, DateStamp 3b7dc5d0
Any idea what this is? I've tried to install 3 separate times now and keep getting the same error. I can enter bios and play around with the boot order and fan control without problem.
So much for a simple first build...
Thanks for your help.
My system:
e6750
Abit IP35 Pro
WD 500gb
evga 8800gt
samsung DVDRW
zalman 9700
antec 900
The error:
