Purchased 2 new Samsung 1T HD103UI SATA drives to use as storage on my XP SP3 system. One of my goals is to backup my music collection which is > 100GB in size. I can transfer "small" amounts of data to these disks but cannot copy my entire music collection without the system hanging.
I have tried both disks, only 1 disk installed at a time, different SATA connections to my mother board, swapped SATA cables, low level formatting a 900GB partiion, and 3 300GB partitions per drive. In all cases, copying my music collection fails. I ran XP's check disk and it shows the 1TB drives to be ok. I have a pre-existing 280GB drive in the system. As a control test, I was able to copy the entire collection to this pre-existing drive with no problem.
Any ideas what my problem is? I thought about updating the ABit motherboard bios but the drives are detected. Not sure I want to "fix" the bios unless I"m sure it's broken.
What am I missing? I appreciate any suggestions you may have.
Did you fix the issue yet? Do you know which SATA mode you are using on the two drives? I think you would want SATA 2. In the BIOS, are your drives set up to use the SATA controller and AHCI mode?
I have found using AHCI mode to be easiest to use although it does require a slipstreamed XP install.
If you are using the "IDE emulation" mode in your BIOS, try googling "SATA hard drives" + "IDE emulation" + "data transfer" and see what you get.
I haven't had that problem but I own a Samsung 1TB (same model as yours) and it works fine so I doubt it's your drives. You tried 'check disk' but there are some disk utilities that would also do a test. I use SystemRescue CD among other ones to prepare and check my drives.
