Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » What air cooling would fit into the Thermaltake Armor Plus MX ?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : What air cooling would fit into the Thermaltake Armor Plus MX ?
Profile: stranger
More Information
Hey!
I'm about to buy my new PC, and at first I choose the Ultra 120 Extreme air cooling
Then i find out that the cooling doe's not fit into the Computer Case :(
So what air cooling does fit into that case?
I'm thinking about Tuniq Tower 120mm or ULTIMA 90I
Can someone tell me if they fit into that case? and if not, what air cooling does?
Related Pr oduct
Profile: addict
Wait a minute, that case is a full tower, every air cooler should be able to fit in there. The Xigmatek 1283 fits in my mid tower Raidmax Smilidon with an inch to spare. These coolers are around the same size.... That Armor MX must be extremely narrow. You could always check out one of the OCZ's or Zerotherm butterflies or what not.
Message edited by spathotan on 07-11-2008 at 12:28:24 AM
Intel Core 2 Quad Q6600 @ 3.6ghz, VisionTek 4870 780 core/1095 memory, 4GB OCZ Reaper Crossfire Edition @ 800mhz 1:1, ASUS P5Q Pro Motherboard with Thermalright mosfets/NB, 580W Mushkin PSU, NZXT Tempest case, 3DMarkVantage - P9599
Profile: member
More Information
No, the thermaltake armor plus MX is a mid tower. And it has a large side fan, which is why a xigmatek most likely won't fit.
Add a reply
Google Ads
