Tom's Hardware Forums » Motherboards & Memory » Chipsets & Bios » 680i wolfdale problems
Add a reply
 Word :   Username :
Bottom
Author
 Thread : 680i wolfdale problems
Profile: stranger
More Information
hey everyone, this is my first build and im having some troubles. I have flashed the new p32 bios on my 680i se mobo so i can use my e8400. i got everything working right(installed vista x64), ran good for about 4 hours then froze and would not respond at vista login screen. i thought it was a o.s. problem so i reinstalled. everything went fine, then about 4 hours later, it froze again while playing oblivion. now it will not post at all throwing up memory errors. tested memory on a friends pc and works fine.
is my mobo done for? any help would be appreciated.
Related Pr oduct
BAM!
Profile: Faithful Poster
More Information
more specs would be great...
however, did you make sure that RAM was seated correctly? Is the RAM running at correct spec (ie frequency, timings and voltage)?
What do you mean by memory errors? have you used memtest86+ bootable at all?
"The MB is 31 C and the CPU is 109 C. I think it's the CPU overheating."
Profile: stranger
More Information
thanks for the reply
system specs:
evga 680i se mobo, e8400 woldale, 2gb crucial ballistix ram(ddr2 800), evga 8800gt 512mb, ocz 600w psu
everything is as it came stock.
the code i get on the hex display in C1, evga says its a memory error
id run a memory test but i can't post anymore
a local techie says that my mobo can't run with my 1333mhz e8400 cpu. what do ya'll think.
BAM!
More Information
Wolfdale cpus are supported in the most recent BIOS update which you have done.
Have you tried single sticks of you RAM to see if you get a post
More Information
Take out your ram.
Reset Cmos.
Boot with no ram you will get an error.
Reset Cmos.
Install one stick.
You should get into Bios now.
Set Bios at specs for your ram. Leaving it on auto is probably under volting.
Save seiings and power down.
Add more Ram.
Enjoy.
Profile: journeyman
More Information
grasshoppa!The 680i chipset is the source of many problems... believe me...
Unfortunately i have the same chipset... Nvidia... :(
Profile: stranger
More Information
thanks guys ill give it a shot and keep you posted
Add a reply
Google Ads
