G
Guest
Guest
Hello!
I decided to back up my files on DVD after I noticed that my computer had a DVD writer (TSSTcorp CD/DVDW SH-S162L), but have discovered that it is less simple than I hoped. I went to buy some DVDs to write, but I was confused by the myriad different types and 'speeds'... I have spent some time trying to find out what 'speed' my DVD writer is, but none of the hardware menus seem to hold this information. Can you help me find out? Also, will I be able to use Rewritable DVDs, or just one-use ones?
Also, is there anything else I should know about DVD writing, since I haven't done it before?
Thanks
Thanks
