Power switch on case does not turn on or off pc. I've tried the reset switch on this case, the power switch from a different case, and turning the plug around with no luck. I tested all the switches with a voltmeter, all tested the same. So I assume the switches are good. The power button on the mobo works. I can turn it off with the power button on my keyboard (cheap GE keyboard) and on with any key on the keyboard (set in bios). I've tried different settings in bios and still nothing. I cleared cmos also. Everything is updated to my knowledge. Not a huge issue, just wondering what is wrong. Any help would be great.
Thanks in advance.
mobo: IP35 PRO
cpu: Intel Core 2 Duo E6850
memory: Corsair Dominator 2x1 GB PC2 8500
TWIN2X2048-8500C5D
power supply: OCZ GameXStream OCZ700GXSSLI
ATX12V 700W
graphics card: XFX GeForce 8800 GTS Extreme
640MB
hard drive: Western Digital Caviar 250GB
cd/dvd drive: Samsung SH-S203B
case: Rosewill R5601-BK
sound card: Sound Blaster X-Fi XtremeGamer
os: XP PRO x64
Thanks in advance.
mobo: IP35 PRO
TWIN2X2048-8500C5D
ATX12V 700W
640MB
os: XP PRO x64
