Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help with Monitor/Video Card(s)
Forum Graphic & Displays : Graphics Cards - Help with Monitor/Video Card(s)
I have read that only a certain amount of pixel information can be sent over DVI if you want to run in native resolution.
From Wikipedia article on DVI:
"With a single DVI link, the largest resolution possible at 60 Hz is 2.75 megapixels (including blanking interval). For practical purposes, this allows a maximum screen resolution at 60 Hz of 1915 x 1436 pixels (standard 1.33 ratio), 1854 x 1483 pixels (1.25 ratio) or 2098 x 1311 (widescreen 1.6 ratio)."
Here is my question:
I have been thinking about getting this monitor: SAMSUNG 245BW Black High Glossy 24"
http://www.newegg.com/Product/Prod [...] 6824001234
This monitor has a native resolution of 1920 x 1200. Will one graphics card be able to run this monitor at its native resolution? I am thinking of getting the Nvidia 8800 GTS (G92) 512 MB card, but I want to make sure it can run this monitor at its native resolution. Or do I need to step up to cards and get 2 ATI 3870s? (I am not a fan of any of the SLI boards, so if I have to go the 2 card route for this monitor to run in native resolution then I will be using Crossfire)
Thanks for your help,
Rawket
Sponsored Links
rawkettz http://www.newegg.com/Product/Prod [...] 6814150253 single should be ok for that monitor
http://www.newegg.com/Product/Prod [...] 6814130312
Message edited by major53 on 01-19-2008 at 11:42:24 PM
------------------------------ ▐ ASUS RAMPAGE EXTREME II ▐ I7 920 ▐ 3 GIG CORSAIR 1600 ▐ BFG 280 GTX ▐ ANTEC 850 PSU ▐ ANTEC 900 CASE ▐ ACER 22" 2216WB LCD ▐ SAITEK ECLIPSE II ▐ LOGITECH G5 ▐
Reply to major53
There are 695 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
