Here are spec's of my rig,
Intel Core 2 Quad Q6600 @ 3,0ghz 333 FSB
Abit IP35 PRO "Off limits" Motherboard.
2 gig ram 2x 1024mb Corsair XMS2 @ DDR 2 835mhz (Dual Channel)
EVGA Nvidia 8800 GTS 512 mb 670mhz GPU core and 972mhz Memory (1944 effective) STOCK
2 x Plextor DVD/RW/RAM drives.
1x WD Raptor 10.000 RPM 150gb (Games and Windows)
1x Samsung Spinpoint T166 500gb Storage
Thermaltake Armor Series Black.
I've got this !@$#@$#@ Issue which is being a horrible pain in the a$$. Whenever I am on my computer my system stutters nearly every minute (not constantly sometimes 2 times in a minute) My old system had this aswell. Everything is brand spankin' new.
I transfered my old stuff to my new computer. Such as, Music and documents.
I have AVG installed and scanned my system 10 times no virusses. Both HD's
I scanned for spyware. No spyware found (except tracking cookies which shouldn't be a big deal)
I do have a big music library which is 2600 songs big and other stuff like some Rar files and Zip files containing software.
I tried watching Task manager but I can't find anything that causes these stutters...
Please help me, this problem drives me mad. I hit my old PC cause of it. But now it's the same again.
PS: Is it normal in Quake 4 @ Ultra Quality 1280x1024 8x AA to have 20-30-60 fps Whenever I play on big fields it suddendly drops from 60 to 30 ... really fast. but it stays on 30.. whatever I do (this can't be normal) with the stutters it goes to 22 and turns back up again.
@ pat,
No the old PC has died :x going to take it away soon. But this PC is running a Ferrari 21" widescreen... @ 1680x1050 but I've always had that problem no matter what my display was.
Is the problem application specific or does it happen with all types of programs?
If you old system did the same thing:
1. Are the symptoms exactly the same?
2. Did you transfer any parts from the old to the new
3. What is the condition of the electrical power to the computer?
Were they both plugged into the same socket?
Try another socket?
What else is on the same socket and same household circuit?
Message edited by rockyjohn on 01-15-2008 at 09:51:08 PM
try the system with no overclocking. Absolutely no overclocking... once more.. no overclocking. Then make sure that your voltages are at default. It could be an OC issue. I would want to eliminate that first.
@rallyimprezive,
I've got 44 processes running at the moment. but I am scanning for virusses , Have avg on, msn on , and my wireless internet adapter. Normally it goes about 29 to 40
@Rockyjohn,
1. Yes, they havent changed.
2. Yes but only music and pictures. Which are intact.
3. Different socket , my tv and monitor is on it, also my heater, and DVD player.. but none of them are on.
@ Hairycat,
Been there done that still same thing.
4 installs at the same time?
G:\Setup.exe
C:\WINDOWS\system32\MSIEXEC.EXE
C:\WINDOWS\system32\msiexec.exe
C:\WINDOWS\system32\MsiExec.exe
hmm ok, so similar to what others have asked, when do you notice this issue occuring, does the frequency of the glitch increase or decrease in certain conditions?
Example: Only happens in games and gets worse as a I play
or
Happens in windows on the desktop when Im not doing anything, and stays very consistant.
and listen to your hard drive if you can, if the hard drive make a loud(er) snap or clicking sound during the glitch, or if the hard drive seems to be thinking a lot.
Lastly, sort processes by memory usage, and see if any are abnormally high. Sometimes corrupt files can cause memory leaks.
EDIT:
Oh yea, what, if any hardware did you transfer from the old PC?
And dont hit this one anymore.
Message edited by rallyimprezive on 01-15-2008 at 10:37:11 PM
1. What PSU are you using?
2. What voltage is your Q6600 and at? What are it's temps?
3. What are your Ram and northbridge voltage? Northbridge temp?
4. Was this a fresh install of the OS on a new hard drive?
5. Do you have all the latest drivers and bios update?
6. Have you run memtest86+ or the latest Prime95 for satbility testing? If not, then do.
Message edited by orangegator on 01-15-2008 at 10:46:44 PM
I have had streaking issues with OC'ed CPU's when the voltage is too high or too low. I am wondering about power. I would look at PSU to make sure it can handle everything you are running. the Q6600 does draw a lot.
@rallly,
It happends while im doing nothing aswell... but it's hardly noticable... I do notice it allot when im gaming or listening music. It's like an FPS drop... The computer is doing something but i don't know what. The hard drive remains stable and doesn't make extra sound.
I did not transfer any hardware. This is a brand new system. Freshly installed Windows XP PRO (illegal though) but should work fine. Well it works fine at my dad's computer etc.
Can't seem to find abnormal high memory usage. Everything is stable...
@OrangeGator,
1. OCZ GameXtream 700Watt power supply
2. Voltage of Q6600 is 1,31 volts I believe (standard 1,3volts and pushes it with 0,01 volts to make it stable... CPUID shows 1,27 @ 3ghz and 1,14 @ 2ghz (speedstep offcourse) Used Dual VS Quad topic here @ tomshardware Idle @ 22-25 Degrees C busy 30 Degrees C
3. Northbridge 25 degrees @ idle busy @ 32 Northbridge voltage is stock
4. Yes fresh install
5. latest drivers yes for videocard. Not for bios. (don't have a floppy or USB stick) But it should work fine cause my other pc had the same problem aswell. I suspect it maybe files which I transferred.
6. No but like I said temps are fine when gaming, (I've watched them while playing Crysis on high settings @ 1680x1050
First off turn off Speedstep etc as described in the overclocking guide. The fluctuating multiplier and voltage can lead to instability when overclocking. Second, run memtest86+ and Prime95. You cannot know if your overclock is stable without running tests.
Hmmm I found something remarkable.. I've kept the task manager open for a few time now. And sorted them by CPU usage... Now everything this stuttering occurs I see a process called System .. and user name System using 2 procent CPU and 512kb memory or less.. and it pops up and goes away again. That happends each time it stutters. Hope this is a clue.
I'll run the tests tomorrow. Please post a download link so I can get back to business straight away tomorrow.
Well, after downloading something..(Intels Processor Id program from INtel.. I ran it on my proc.. guess what... 3 out of 4 cores were somehow disabled???!?!?!? and get this it was windows that did it!!
I looked in device manager under the computer tab, and it showed a single core ACPI PC, although CPU-Z saw it as a quad core and the intel program saw it as a quad, Windows was calling it single, and since I couldn't figure out how to switch this setting.. (i tried everything besides pulling the proc out and reinstalling....) I decided it best to just reinstall windows.. And guess what...it's fixed everything.. I now show Mulitprocessor Cpu in Device manager, and I just ran Aquamark 3 without any OverClocks at all just a base system with my SLI configured.. and I scored better than before with everything overclocked... Now intel ID shows all 4 procs running @ 2.40 ghz at 1066 FSB... anyways it's really late...(6 am in the morning here) and I dont have anymore energy left.. so tommorrow benchmarking for Dragon Cyber. Thanks for all your thoughts and advice guys, !!
Are you using the same PowerSupply as before? Are you using the same ANYthing as before? I've had this problem before, and it always came back to the PSU or possibly a driver issue..
in the Device manager tab it shows ACPI multiprocessor PC, so that should be ok. I'm not going to reinstall windows yet, since this just has been running for a month now.
@doormatderek,
No it's all new except for the transfered file. and my printer, but it was already before i even installed the printer. I do use the same mouse, which is a Razer but that shouldn't be a problem ?
Downloading benchmark programs now. I'll post later on.
When you say it happened on your old computer, and you transferred no components to the new system, it would indicate that the problem could be outside the system.
You listed what you had plugged into the socket, but I don't think you identified if anything else was on the CIRCUIT. Multiple sockets, fixtures, and appliances can be connected to one circuit and affect current flow. Is there anything else on the circuit? You may need to look at the fuse box to try to identify the different circuits in your house and what might be on the one with your computer. You might also need to turn the breaker off and then check sockets to make sure you know what is on the one circuit.
I fixed the problem!!!!,
It was my network adapter. My Linksys WUSB300N Driver... which I didn't used, collides with the Windows Wireless XP Zero standard utility. My Linksys router is N so that's why it probaly crapped up my XP.
Anyway thank you everyone for all the tips! They are very appreciated.
Keep up the good work,
Radium
