Try mini-itx.com. They're more for in car or HTPC though, so the power might not be as high as for a full desktop, just 120W.
Alternatively you can just buy a 12VDC-110/240VAC inverter and run any computer off it, although for PC use you'll want one with a good sine wave AC output, as computer's don't run reliably on the poorer quality ones.
