Yes No
Ads
Power supply
Forum Windows Vista : General Discussion Power supply
fan keep runing after new install. this is a 400w coolermaster. Installed in a Hp pavilion a6700w stock . no work load idle state. did have a minnor issue with the mobo connect 20/24 pin set up . 4 pin came loose . would like to se if there is any other input on this issue.
Reply to zallidor
If it is like that, its OK. BTW the 4pin has 2 teeth to lock with 20pin to make 24pin.
http://www.nexustek.nl/images/ext-24_closeup.jpg
------------------------------ Where there's smoke, there's fire...
Reply to Nikorr
Thanks that was it . Reseated the four pin and all was good. Thank for the reply . I like the fact that u included pic with answer.
Reply to zallidor
Older mobos come with 20pin and newer are 24pin, therefor u don't have to change the PSU if u upgrade the mobo, when it comes to that.
Reply to Nikorr
well the p/s was working fine and then the pc stops working . I went into the case re-seated the mobo cables starts up fine than stops working reseat the connectors agian works fine , got a call today not working agian . me think its mobo any ideas
Reply to zallidor
Is it pushed in all the way?
Reply to Nikorr
BTW, post specs for the PC and how old is the PSU?
Reply to Nikorr
Hp pavilion a6700w stock. had a 300 watt replacement is a 400 w . so 100w more then spec.
Processor
AMD LIVE!™ Made to Bring It All Together
• AMD Athlon™ 64 X2 Dual-Core Processor 4200+
• 2.2GHz, 512KB+512KB L2 Cache
Operating system installed
Genuine Windows Vista™ Home Premium
platform
Chipset
NVIDIA nForce 430 Chipset
Standard memory
1024MB
Memory type
DDR2-SDRAM
Memory slots
4 DIMM (184-pin, DDR2) (two available)
Reply to zallidor
Tom's Hardware > Forum > Windows Vista > General Discussion > Power supply
There are 1620 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I cannot get my external hard drive fully installed on vista
By nhasian, 1 day ago:
rather than fdisk it is recommended to use Disk Management. Create and format a hard...
Best offers
Top experts
