Slave HD probs can any one help?
I have a slave HD but when i plug it in i get this
Can any one help. The slave is connected using IDE and my Primary is SATA. (only running HD on the IDE cable no DVD drive as i unplugged it to rule that out)
14 answers Last reply
More about slave probs help
  1. My board is ASUS M3A if that helps.
  2. Also
    So i take it my HD is dead?
  3. Are you able to boot ok when its just your primary HDD in?
    Is your primary's jumper set to Master?
    Do you have multiple IDE ports on your MOBO?
    What IDE port do you have your HDD's plugged into?
    Are you using any and SATA devices?
    Are you able to set any of the SATA options in your BIOS to IDE?
  4. Your 125Gb drive on Primary Slave connector is failing on SMART status and is also failing to communicate correctly. Try reseating the data cable, at both ens, or try another cable. If no change, the drive is faulty, and requires replacement. Check if under warranty.
    Mike.
  5. If the only device that you are using on your IDE controller is the hard disk then it should be jumpered to be a master; If not, that might be your problem.
  6. Even tho my main HD is master?although it is on SATA and not IDE
    So i will have two masters one on SATA and one on IDE
    Yes when the slave one is not plugged in it all fine,
  8. I have formatted the slave drive and it works now but i still get the same error as pic 2 above :S
  9. Masters/slave is a relationship between two devices on same IDE channel. If you have only one device on a channel it must be a master. This has no connection with your SATA drive(s) or which disk is your boot disk.
  10. Quote:
    :o
    Could you give some referenced for this?
    6351stuart. the drive is still giving SMART failure, it is going to fail again! :bounce:
    Do yourself a favor and change it now.
    Mike.
  11. Link. Also, make sure your disk is connected to the last connector on the cable, not the middle one.
    Whatever the theory, try it and see! That's the way I solve computer problems.
  12. Quote:
    Note that despite the hierarchical-sounding names of "master" and "slave", the master drive does not have any special status compared to the slave one; they are really equals in most respects. The slave drive doesn't rely on the master drive for its operation or anything like that
    If only one drive on cable it doesn't matter which connector, the drive will work fine. 6351stuart has a SATA drive, which is his boot drive.
    Mike.
  13. You missed:
    Quote:
    Also, a single device on an IDE channel "officially" should not be jumpered as a slave. In practice, this will often work despite being formally "illegal".
  14. Now you will get all kinds of opinions, cable select settings, and different advice. Problem is, not all BIOS's for whatever reason will detect and work correctly using other settings, or it the drive is plugged into the wrong place on the ribbon.
    To insure the drive WILL work....plug the drive into the end of the cable, set the jumper on the drive to master. If you hook up a second drive to the cable, put it in the middle, set it to slave.
    Ensure that you have the ribbon cable plugged in the correct way. The side of the ribbon with red stripe is pin number "1". Make sure the red stripe corresponds with pin "1" on the board, and the drive if the cable has no notch to orientate it correctly. Some ribbons, believe or not do not have the notches on the plugs. The pins on the board and drive are marked right next to the plugs where pin "1" is.
    Has no bearing on your SATA devices, your boot order in the BIOS can be set to boot from the IDE or your SATA device first, second, third, fourth, fifth and so on, or not at all, in your BIOS.
    If you still get an error, the drive is likely failing.
Hard Drives HD DVD Drives Storage
