I would suspect the cable or magnetic interference. If there are signal losses or shielding problems I think you would get those symptoms. Can you test with a short high quality cable? If it works properly, then it is the cable. If you need cables, go to www.cablesforless.com I have bought from them before and been very satisfied with service and quality. https://www.cablesforless.com/index [...] tegory=814
I am thinking the same thing also..
I am doing searches on Wireless Media players and there is a lot of netgear and d-link.. not sure if those are any good or not.
50' S video is well within the specs. Should not be the problem itself unless poor cable quality. 150' is ok usually. Is the DVD output set on interlaced? S video is only interlaced not progressive scan.
