Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help with Power LED wire
Forum Homebuilt Systems : General Homebuilt - Help with Power LED wire
My power LED cable from the case is too short to reach the mobo. How can I lengthen the cable? Any help is appreciated. Thank you.
Sponsored Links
just cut the connector off the end of the cable and connect two longer wires to the existing wires, and put the connector on the new end.
{}=====================LED
{}==========/ /========LED
(cut cables)
{}=========/ ======================= /==============LED
(add two new wires)
{}================================================LED
(use wire nuts/solder/electrical tape to bond the wires together.)
easy as pie.
which is not easy for some people...
but still, this is easy.
Reply to frozenlead
You just need some extra wire of the same size, and some electrical tape. I would do what is referred to as a j-hook on the splices. Simply bend the exposed wire so that it forms the letter J. Then hook the 2 together, and twist. It is best that you solder this joint, but not necessary. Once you are done, simply cover with a few wraps of electrical tape.
------------------------------ I know what I know, and I don't know what I don't know.
Reply to tlmck
That's unusual. Check to see if it is hung up on something. Last year I got a case on which the front panel screws on. The drones who assembled it put a screw through the power switch wires.
If that doesn't help, buy a roll of 22 gauge stranded "hookup" wire. Cut the two wires of the LED cable at least a couple of inches from the connector. Strip 1/2" of insulation at each end and splice in long enough pieces of the hookup wire to reach. Cover all the connections with electrical tape.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Thanks for the help.
Reply to AlexViper
If you don't want to make one for yourself, you can order an extension cable: from frozencpu.com http://www.frozencpu.com/products/ [...] d=hJpVZ2ZY
Reply to geofelt
I dunno... costs Price: $1.99 :kaola:
If it were me i would order it, its the lazy way.
Reply to grieve
There are 609 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
