If I get some wire mesh or something like that from home depot, mounted it over the side of my computer and opened my side panel, and then put a high powered electric fan right next to the tower and blow air inside it like the dickons... what would be the draw back to that? Case fans move such little air. Some electric fans can move more then 1000 cfm on low settings. Thoughts?
I have been constantly searching for new and creative ways to cool the system I wish to buy effectively. I've even considered putting my computer in a mini freezer and punching holes in the back to feed the wires (I would still- but anything big enough is too big and too expensive).
Has anybody else heard of any exotic ways to cool a computer? Ideas are always appreciated (and usually amusing
Not only will a desk fan solution look stupid, but there's probably a good risk of damaging components from dust/particles moving at a high rate of speed.
| mothergoose wrote : I've even considered putting my computer in a mini freezer and punching holes in the back to feed the wires (I would still- but anything big enough is too big and too expensive). |
Here we go again, quite a few threads try to explain that this will not work. Has someone actually tried it (and posted any pics)? I would love to see the damage done...
mini fridges are 90 bucks !
to the op as far as your fan theory goes...screw the desk fan and use a 20 inch box fan and just seal it up to the side and try that.
,,dust particles don't have enough mass to damage anything, go learn what MASS is.
Lol, if this thread will offend people then please ignore it and I won't bring up the subject again. Not worth getting flamed over. CtrlAltDel, I would be interested in reading those threads if you could post them.
EDIT: I did find a cheap box fan (35 dollars) that is supposed to be relatively quite, and move more then 2000 cfm. Very exciting! And cheaper overall then six to eight high powered case fans that couldn't couldn't move half of that.
I would think your avg fan @ 15 bucks would be more than plenty. Also, put your mb in a tube and run wires out the top, have a fan that just fits each end and voila.
Well, I doubt anyone was talking about the individual pieces of dust actually punching through a component, the problem is the collection of dust. Dust will collect in all the cracks between the fins of heatsinks and anywhere else it can hang on. The collection builds and becomes an insulator, keeping all that heat nice and close to the components.
Anyway, enough about the obvious concerns with dust. Fans have been getting larger and larger for a reason. Larger fans can push more air at lower (quieter) speeds. So the idea of a larger fan is actually a good one, however you gotta think of air flow too. Pointing the fan at the board just makes the air hit the board, but you don't know what kind of chaos that's going to produce. Pushing more air over it will help move it along, but you won't be getting the kind of movement you would from something as simple as royalcrown's idea. You want a FIFO air flow, the first air in should be the first air out, without proper flow, this will not be the case. That means the warmer air could be trapped in a pocket in the chaos (think whirlpool in a white water river).
I might actually google the heating properties of air since I'm curious to see if there's actually a point where the air's ability to absorb the heat effectively is actually hindered by movement. I mean, if you think about it, heat isn't absorbed instantly, maybe moving the air particles too fast could actually not give it enough time to absorb any heat? That would be freaky!
Air flow doesn't absorb heat, it moves it. The particles in the cooler air collide, push, and generally force out the hot particles to create cooling. FIFO is a valid idea, but the way air works is it will always be moving the warm air out any place it can form an air pocket. What happens is the air travels until it collides with a solid object, moves across it to the point of least pressure to escape, and keeps going. All air behind it follows the same path when the airflow has been established. Even air pockets circulate new air through over and over again or the "pocket" couldn't exist. It would just collapse into stale, still air. Dust could be a problem though... but no more so then with any other case fan. Hopefully home depot will have a cheap screen I can buy to solve the problem
szwaba67 you're right, installing an out-take fan moves heat better than an in-take fan - finally firefighting has helped me solve somebodys problems over the internet. if you want to get REALLY technical then you could set up a small hose before the out-take fan which creates a lower pressure (if i remember correctly) and can massively increase the heat out-take. bahahaha if you're really worried about it then you could take everything out of your case and fill it with smoke and try running the fans without the parts in it - this will allow you to see how effective your fan placement is
sorry - edit that - out-take fans move AIR better than an intake fan.
you could always try leak-proofing your case and filling it with vegetable oil. not only do you have a cool computer but you can cook stuff while your games load!
^lol
If you don't care how it looks, it will defiantly move some air. Just make sure and put a filter on the box fan so your system dose not get clogged up with dust.
mothergoose... I'm not sure what you mean. The "hot particles" that you refer to are AIR, thus, the cooler AIR (cooler particles) that are colliding into the "hot particles" are simply "moving" the heat away. You say AIR doesn't absorb heat, well how the heck did those particles get hot!? Once the cooler air is in the space that the hotter air once was, it absorbs the heat from the components and thus becomes hotter than the cooler air being forced to it.
I do like your theory on "the way air works" but it doesn't seem right. The idea of a pocket is that the air around the pocket is colliding into only the outer edges of the pocket, forcing the air in the middle of the pocket to swirl. I agree SOME air is moved through this pocket, but it still creates a hot spot because not ALL of the air is moved. Think of the back of a pickup truck on a highway (please excuse this seemingly redneck comparison). You get an air pocket causing air to swirl in the back, so if there's leaves or something they just swirl around and around. Sometimes they fly out when the pocket is disrupted, otherwise, just swirl around and around. Picture this on a much smaller scale, with just AIR, the warm air particles instead of leaves, and fans inside a case instead of 60Mph speeds on a highway. Why is that not valid?
What's up with the cooling ides? This is the 2nd one I have see today
http://www.tomshardware.com/forum/ [...] g#t1767744
Any ways OP post back with results. Good luck.
| Shadow703793 wrote : What's up with the cooling ides? This is the 2nd one I have see today
It's the summer, people are getting desperate.
outlw6669 - LOL. I dont see why not.
Have you seen some of the 250mm + fans they are putting on cases now?
Just spend a few extra bucks and get a quiet fan.
LOL.
| alanman wrote : there's probably a good risk of damaging components from dust/particles moving at a high rate of speed. |
lmao...you serious??
Anyway, if you're going to leave the side open, there's no need for a huge fan. You just need a small desk fan at the bottom in the front of the case pointing towards the base of the processor heatsink. This provides more than enough cooling for all of your components.
A reasonably well-designed case with intakes in the front and/or side and exhausts in the rear and/or top should efficiently remove heat without a noisy rush of wind or whining of turbo fans. A box fan would probably work very well too, but be noisy, bulky, unsightly, and inefficient. There are some cases out there that have larger fans for more airflow. XClio and Enermax come to mind, but I think there are others too.
| outlw6669 wrote : If you don't care how it looks, it will defiantly move some air. Just make sure and put a filter on the box fan so your system dose not get clogged up with dust.
I like it
| jtt283 wrote : A reasonably well-designed case with intakes in the front and/or side and exhausts in the rear and/or top. |
costs too much for some people (like me).
in winter just open the window better than a fan
Bunus with outlw669's idea.
That setup will create positive pressure in the case. All openings will become exhausts. Reducing the dust coming in from unfiltered openings. If you were to spend a couple of dollars on a good little better filter, that could work well for dust control. Even at low speeds. You would still need enough openings to allow the air out or you will not get any flow.
I would suggest getting a quieter fan and a better filter. Cheap house A/C filters dont stop the fine particles that can mess up circuitry. Get a good house a/c high flow hepa filter.
You would still want a fan on your heatsinks.
adding an 80/120mm exhaust fan with a fan controller might help if you dont have enough exhaust openings. If the case has to high a positive pressure from the box fan, you will get no airflow no matter how big it is. the air needs a way out.
why you care about dust it wont damage your pc
just buy a can of compressed air and done
my pc is covered with dust and it work fine
I can always drill some whole in my case to let out some air in the back and sides. I think with the air coming in from one source and going out the vents I should have something like the FIFO szwaba was talking about.
Actually, I may have found a better solution. I found a case that comes onboard with the power supply I want and a 250mm side intake fan. That's almost the size of a small desk fan. I went shopping to see if I could find a 250mm case fan with good airflow and there aren't really any that push a lot of air for that size (most I saw was 105 cfm... good but not what I want). Is is possible to up the rpms on a fan like this with a fan controller to be able to move more then this much air ( a lot more)? Can you adapt other types of fans to fit in a case? What are the specifications for a fan such as this if I wanted to go to a hardware store and try to find something similar? (I know it is 12v and the size but not sure what else it important).
well I guess one option would be this fan if you want to move alot of air and it should fit in a 250mm slot (or be modded to easily) since 250mm is a little more than 9inches http://www.grainger.com/Grainger/items/7F670
I've got two fans (smaller) very similar to this one but I very rarely use them since I have to plug them into a wall outlet, but god they move so much air to fit in 120mm slots
btw thats a 500cfm fan
last post sry, here is another fan I found http://www.grainger.com/Grainger/items/4WT44
fans like what i'm showing you we use in big cabinets that house PLC's, profibus modules, and multiple cards. Needless to say alot of heat builts up in these massive steel cases...yet the most i've ever seen is 3 of these http://www.grainger.com/Grainger/items/3LE74 and for the amount of electronics in there it stays very cool
Do you personally use any of these fans Laminator? I really appreciate the links- very helpful. I will be using one of these more then likely.
Question: Do they have independent outlet jacks or can they be modded to fit a powersupply (or both- an independent jack might be nice)? Do you know how much cubic feet these move? The link didn't post. Thanks again ![]()
EDIT: Nevermind the airflow question, I can't read
You realize those are 19-23w fans, right? That's an incredible amount of juice to be pulling for a cooling fan for a computer...Why not just go with A/C powered fans:
http://www.frozencpu.com/cat/l3/g3 [...] Page1.html
I think you are getting a little overzealous here...something like these will most likely be fine for any application:
Your probably right... I don't need a fan that big. But I want one. Besides, I looked at the fans you posted (the 250mm one anyway), and it only moves 105 cfm. The one laminator posted moves 500 cfm.
At some point, you will reach an air-mass threshold that won't make any difference how much more air you are pushing. There has to be a physics equation for this, but it might be entirely too advanced for the sake of cutting holes in computer cases.
$40-$65 for one of those Grainger fans?
Why not just get an excellent CPU cooler for that price...?
Modding is your own free will...good luck with your end choice.
Rubix- the fans are AC not DC so if you pull them with a PSU I would be truly amazed. Also if used for exaust it would allow for negative pressure within the case, and the laws of physics do apply you're right, outside air will fill the void left by negative pressure.
mothergoose- the ones that i use from time to time are pretty old now but are very similar to http://www.grainger.com/Grainger/items/3LE74 except in a 115 v unit rather than 230v. These fans are AC and you're PSU is DC meaning that you'll have to use a wall outlet. What i do with the 2 i have, i don't even mount them. I have a cooler master rc-690 case which is pretty much all mesh. I just place the two high speed fans on top of the case and use them for exhaust and believe me they put a hellacious amount of air.
Let me know what you decide on and how it turns out i may decide to try something like this (more permanent) myself
actually these are the same ones i use, i just found them http://www.grainger.com/Grainger/items/4WT46
Ahhh...I guess I didn't look closer.
Still, you can never achieve lower than ambient temps with air (or water) and you are still dependent upon the ability of your heatsinks to effectively transport heat away from the processors and into the heatsink where it can be conducted to the passing air.
Why not make it good?
http://www.mdhydro.com/squirrel-cage-fans.html
Cut holes, mount to side of case, plug in wall. I am guessing CFM isn't always an apples to apples comparison. Next step is a diesel powered wind turbine...
I am going to get a xiggy and a passive cooler for my gpu anyway. I am just a performance buff. I want the most for my money. I think I am going to get my case, install heatsinks, and run it standard for a while to gauge temps. Then I'll take the side panel off, blow a high powered fan in the case, gauge temps then, and see how much room there is to improve. If I can get my temps to drop a whole lot when I blow a desk fan on it then I will look into buying one of those monster fans. If not then I'll save my money. It would be cool to brag about having a side fan the moves that much air, lol.
o i totally agree with you, u won't get below ambiant on air or water, but half the fun of modding is being over zealous and extravogant.
4ghz on a Q6600 with a side mounted car oil cooler and custom res's...I know exactly what you mean. Not always logical, but fun and functional.
wow lol if thats your system will u please pics i've gotta see it
I have a 2x120mm rad on the back of the case as well.
Dangerden pump, TDX block, NB block, Swiftech MCW60 GPU block.
I made the res's out of acrylic tubing, but would like a cleaner look...working on v2.0.
I've purged more air and filled the res's completely with coolant now...need new pics it seems. I guess that's in the works. Maybe some LED lights behind them as well...
Wow, that's amazing. Are the temps under load?
How much did the water block cost you? Does it get your mobo and gpu as well?
there is a thread on here somewhere and i can't find it now, where some guys took an air conditioner and ran alcohol through the coils to drop the temps down to something like -30F (had to cut the fan off the condenser of course) and pumped it through waterblocks in the system, it was pretty cool but they problems with condensation
I think I took that just after I ran 3dmark06...under load I haven't seen it hit above 50C on any core. GPU never gets above 48C. NB is also cooled by a waterblock; I might not have been allowed me to hit those speeds without cooling the NB with water.
I think the CPU block was ~$55
NB block ~$25(?)
GPU block ~$40 ($45?)
I have used these same blocks for the last 3 builds...just needed different brackets for the GPU; CPU blocks usually come with 3-4 diff brackets, but LGA has been the same...
Hm... Danger Dan? I have heard that name before.... maybe some day I'll have too look into that. One sweet set up you've got
i'm gonna have to check this out when i get home, stupid work computer won't let me see pics
| Quote : there is a thread on here somewhere and i can't find it now, where some guys took an air conditioner and ran alcohol through the coils to drop the temps down to something like -30F (had to cut the fan off the condenser of course) and pumped it through waterblocks in the system, it was pretty cool but they problems with condensation |
Saw a guy at a LAN that had done something similar with a refridgerator condenser. He had the coils running through a tank (what appeared to be a 5gal fish tank) full of coolant which he had pumped using a fish pond pump and 1" tubing and some copper junction blocks he found and milled a little. He got below ambient temps (obviously), and was sitting around 2-5C under load that way. It was pretty ugly looking, though.
I guess a 5 gallon bucket full of dry ice and water with some fittings running in and out might also suffice, but like this guy, make transporting your rig difficult. He had a 5 gallon bucket full of coolant and had to reprime his entire system every time he moved it. Not cool. Mine is set up with the case strap in place...grab and go.
I want to do a custom job like that before i get out of college, not sure what i'm gonna do yet but i definitely want to try something out
I started out pretty basic, my first mod was carving Matrix glyphs into the side of an old case and adding green cathodes behind plexi. Looked OK, I had shards of steel in my hands for a week. Thank you tetnus shots.
Watercooling leads you down new roads for customizing.
mothergoose, check out this fan !
http://www.frozencpu.com/products/ [...] =g36c15s73
There are 455 identified and unidentified users. To see the list of identified users, Click here.
