Gateway vidieo problems
how can i find out why my vidieo isnt working on my gateway performance p4 1300 i dont know if it is a jumper on the bourd or what
1 answer Last reply
More about gateway vidieo problems
  1. I think you should try a repair install of the operating system. See the fourth post from the top in Tom's XP forum.
    You will need the gateway XP install disk or the XP install disk.
    Not a jumper.
Video Performance Gateway Jumper Windows XP
