I have a problem with my current system. Basically, I suspect there is a hairline fracture in my mobo, so I'm going to do a wholesale upgrade (minus GPU, which I am happy enough with for now, and my X-Fi). The thing is, I have a watercooling system. I don't OC at all (although I might this time); I got it just for fun. The point is, I wouldn't mind axing it.
Anyway, onto the gorey details. I am going to go with an Intel Core 2 Duo E8400 (when it comes out) and some DDR2 RAM. I'm not sure which board to get (or which specific RAM for that matter). If I drop the watercooling, I need to spend some money on a new case. If I keep the watercooling, I need to spend $13 on some brackets. However, I'd also like to get one of those ASUS boards with the waterblock built in if I keep the watercooling.
Now, those boards cost at least $300 (unless you guys are aware of another one with a built in waterblock), which is more than a reasonably priced board, a CPU fan and a case (less $13 for the brackets). Also, the watercooling isn't much quieter (the main reason I got it) with new GPUs that need hurricane force winds to cool, and a waterblock for a card can cost almost $100. Here is the additional rub: my current GPU is an AGP card, so I'd like a board that has AGP and PCIe (do ones that support the CPU I want even exist?).
So, what are my options? Like I said, I don't mind dropping the watercooling if I have to. I'll also buy a new GPU if I can't get a board that supports AGP, PCIe (for the future upgrade) and a 1333MHz FSB.
While you're at it, any suggestions on RAM and a HDD?
