Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Using Case Fans... Where to connect?
Word :   Username :
Bottom
Author
 Thread : Using Case Fans... Where to connect?
Profile: member
More Information
I put together my P182 with a DSL3 and a Corsair 520HX last night and I wasn't entirely sure the best way to connect my 5 fans... There were numerous places on the MOBO to connect the fans... but I decided to go with connecting them all on one power cable from the PSU.
Is the the best way to do it?
Also, I have some of the fans "chained" together (plugged one to another) is this okay? I considered every other little detail of my build, but never gave fans much thought.
Thanks in advance.
Q6600 G0 @ 3.5GHZ | GIGABYTE GA-P35-DS3L | ANTEC P182 | XFX 8800GTS (G92) 512MB | THERMALRIGHT 120 ULTRA EXTREME | CORSAIR 520HX | PATRIOT EXTREME 4GB (2 X 2GB) DDR2 800 | SEAGATE 7200.10 | SAMSUNG SH-S203N |
VISTA 64 HOME PREMIUM
Related Product
Not smart enought? Try Harder!
Profile: stranger
More Information
You should use the ports on the MOBO because they can be controlled if they are on the power then they are on full blast the entire time. Using the MOBO can reduce power comsumption even tho this is not alot, also over all noise levels. i would put the back exhaust fan on the power and the front intake fan as well, then use the remainder on the motherboard...
Hope this helps
greetz
South Africa
Why do they Sterilize Lethal Injections?
Cooler Master Stacker Case SE
550W PSU
OddJob's side-kick!!
Profile: Honorary Poster
More Information
I find using the 3pin connector makes them a bit quieter then using the molex, just a bit though.
Na na na na na na na na HATMAN!
Profile: member
More Information
Unfortunately mobo makers don't include the maximum wattage of the fan headers (in which case I'd say it's their problem if you blow the board) after a lot of searching I found 3w to be the maximum recommended per fan if all the headers are used, or 5w per fan for up to 2 (not a concrete recommendation though). Any standard fan should be fine (most 80mm and the slower 120mm ones). I chose not to put my two 140CFM Deltas on the fan headers though as they pull nearly 10w each.
Profile: member
More Information
I'm using the Antec Tri-Cool 120mm, which I believe is 5W on high. I guess its best just to go with ol' Molex then.
Personally the sound doesn't bother me much, and in the P182 they are actually pretty quiet. I was mainly worried about chaining 2 or 3 together. No problem there... right?
Google Ads
News
Artic Cooling's Triple Fan Graphics Cooler
Published on January 11, 2008
Those looking for the biggest thing in graphics cooling may find the new Accelero Xtreme 8800 and 2900 coolers a perfect solution. Read more
Behold the five radiators, six graphics cards and 50+ fans “DayWalker” system
Published on August 29, 2008
San Jose (CA) – While many of the case mods we saw at the NVISION conference and LAN party were extraordinary, the “DayWalker” Blade-themed case - or more accurately towering, human-sized, case – impressed us the most. Read more
CES 2008: Sharp Looks To Network HDTVs Through Power Lines
Published on January 10, 2008
Sharp is introducing a technology called Aquos Net that brings Internet content and remote diagnostics to Aquos LCD TVs at the touch of a button. Read more
RocketGuard 100 monitors temperature, alerts about failing PSUs
Published on February 07, 2006
HighPoint Technologies, makers of RocketRAID line of RAID controllers, has released the RocketGuard 100 monitoring card which keeps track of chassis temperature, fan and power supply health. The little card can be mounted anywhere within the computer case and has connectors to HighPoint's RocketRAID cards and chassis alert LEDs. Using the included software, users can set alert limits and be emailed when a fan fails or when the case reached a certain temperature. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
