Problems running 2 RAM of different PC
nabildib
Dear Sir I had HP Laptop Pavilion 6700
My DDR2 Rams was: 1- 2 GB pc5300 667 MH + 1/2 GB The same
Lately I replaced my 1/2 Gb with 2 GB pc 6400 ???????
Now and then I got a message my computer was unable to start!!!!!!!
Could be this difference in Rams Pc is the cause
The ram is compatible, but you may be running a slower speed of 5300.
Check the event viewer to see errors being reported (if any)
^ don't think he can check event viewer when the PC does not boot.
Well, you replaced the RAM, and the PC did not start right after that. I'd say the issue is because you changed your shirt, try a new shirt.
If you want to try to use the faster RAM, replace the old one, do a bios update from the vendor support page, try again. You can also try just using the faster ram without the 5300 in there. But the laptop may just not want to work with the ram you have.
Well, he said,
So i guess he can get into Event viewer.
