my config is the fallowing:
p5n32-e sli 680i chipset (bios 1103 release version)
a-data vitesta extreme 800+ (4-4-4-12 2T, 2.025v, 800mHz, 4x1gb)
q6600 (stock speed + AC freezer 7 PRO)
asus 8800gts 330mb/320bit (stock speeds)
antec basiq power 500W
1x WD 320 s-ata 16mb
asus dvd-writer s-ata
OS Win Vista x64
I cannot install 4gb of ram on my mobo ... reason unknow so far :|
i prolly tryed everything possible... loosing the timings, increasing volts, installing vista with 3gb and then putting anoather 1gb in, what else ?does anyone had the same problems im going through?what is ur opinion ?
made my system work ... 4gb a-data BUT .... with my cd-writer unplugged. if i plug it in, i cant even load windows (bosd). i tryed a non s-ata writer .... same problem :|
I would check the manual for your mobo. p5n32-e has had many problems as you can read from newegg.com http://www.newegg.com/Product/Prod [...] 6813131073 id contact asus for tech support. Then play the waiting game. Always fun!
------------------------------Life is not a journey to the grave with good intentsions and mildmanners, Rather a skid in side ways throughly messed up, totally worn and used up, Loudly proclaiming. Wow... what a ride.
Reply to wing
Yeah I have the same motherboard, there has been alot of problems with ram and this mobo, there is a document on the asus website listing supported ram for the mobo. my g-skill isn't listed but thank goodness it worked for me with 4-4-4-12 timings.
Go to Asus website and get bios 1302. It will probably solve your problem. Whatevevr you do don't try 1403. It is a beta flash and it just wiped out my bios chip. Waiting for new bios to come.
R Collins
Message edited by kg4icg on 03-02-2008 at 01:08:03 AM
------------------------------Did I hit you with a Mack Truck?
Reply to kg4icg
thanks for the comment m8, but i don't really wanna change the DIMMS only if its the only solution ... im also looking to change my mb since this one has some problems... but who know's maybe i can figure what the problem is ^^
well well well, im looking to change my mobo ... i would like to know a good one maybe with x38 chipset or 780i wich supports 4gb a-data vitesta extreme 800+. does anyone know any?pls
