P5N32-E SLI PROBLEM, help ASAP pls!!!
my config is the fallowing:
p5n32-e sli 680i chipset (bios 1103 release version)
a-data vitesta extreme 800+ (4-4-4-12 2T, 2.025v, 800mHz, 4x1gb)
q6600 (stock speed + AC freezer 7 PRO)
asus 8800gts 330mb/320bit (stock speeds)
antec basiq power 500W
1x WD 320 s-ata 16mb
asus dvd-writer s-ata
OS Win Vista x64
I cannot install 4gb of ram on my mobo ... reason unknow so far :|
i prolly tryed everything possible... loosing the timings, increasing volts, installing vista with 3gb and then putting anoather 1gb in, what else ?does anyone had the same problems im going through?what is ur opinion ?
Related ressources
My guess is it's the memory causing the problem you may have to try a different manufacturer. Also when you install Vista 64 do it with only 2g of memory and make sure all the updates for Vista are on your machine then add the other two gig.
I have the P5N32-E plus board and added 4gb (2x2) adata RAM and had all sorts of memory crashes and lockups until I changed the following.
1. Change FSB to unlinked
2. Change LTD Frequency from 4x to 5x
I left all the other settings alone.
Ask the community
