wifi phone/wifi voip phone/wifi ip phone Model WP04
Using SIP Wi-Fi phone WP04, you can make calls worldwide over the WIFI network without being tied to your computer at zero or lowest IP cost. It can be used at the office, home, airports, hotels etc. WP04 WiFi headset is a smart slim design wireless VoIP phone which supports 802.11b/g, SIP2.0, G.722, G.711a/u-law and more.
Basic Feature Support roaming feature
Support SIP URI address dial among different servers.
Support WPS(Wi-Fi protected setup) registration
Support direct IP address dial.
LCD display: 1.5" colour TFT 128x128, 65K colours. Adjustable contrast.
Long standby: about 140 hours.
Longest talk time: about 7.5 hours.
Support three kinds of dialling methods: IP, Digital number and SIP URI.
Phonebook / call logs
Call Reject / Redial
Caller ID /Anonymous call
Missed Call indicator
Call Vibrating Alert
Language support: English, Turkish, Korean, French, Portuguese, Russian, Dutch, Chinese even more languages can be customized.
Hands Free / Mute /Earphone support
Volume Control buttons
5 ways navigation paddle
Key Lock function
Keypad Backlight
Time / Date remain while the battery is off.
Supports 802.11b/g, IEEE 802.1x, 802.11i, standard SIP2.0
Auto Wi-Fi (Wireless Fidelity ) Hotspot Scan, Net Search
Security Settings: WEP 64 / 128 bit encryption/ WPA /WPA2/ MD5 Authorization
Supports WPS registration
Supports 4 SIP profiles register.
Supported codec: G711a/u-law, G722, G729a/b
Supports DTMF RFC2833 and RFC3261
Comfort Noise Generation (CNG)
Voice Activity Detection (VAD)
Acoustic Echo Cancellation (AEC)
Support Stun server
Support Proxy
Direct IP call without SIP registration
USB charging and firmware upgrade.
Light & breast pocket smart style design
LOOKIT provide the reliable SIP service embedded value-added service customized menu
Accessories & Packaging
WP04 SIP Wi-Fi Telephone
USB cable, Earphone
Cradle for power charge and for Access Point plus power charger.(for choice)
Li-ion Battery: 3.7V, 850mAh
Power adapter: 100-240VAC, 60/50Hz
User manual
Colour box size: 150 * 130 * 45mm
Carton box size: 395 * 56 * 415 mm, 60pcs /carton
