Tom's Hardware Forums » CPU & Components » CPUs » OEM?? first build help
Add a reply
 Word :   Username :
Bottom
Author
 Thread : OEM?? first build help
Profile: stranger
More Information
i got this set up i made with a 200£ budget..its not complete yet but i just wanted to know whats the difference between a OEM processor and a normal processor (is it just extra info?)
Corsair (VS2GBKIT667D2) 2GB (2x1GB) DDR2 667MHz/PC2 5400 PC Memory non-ECC unbuffered CL5 - Lifetime Warranty - CORSAIR
In Stock
Sold by Digital Components Ltd £29.40
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Ethernet - video - High Definition Audio (6-channel) - Asustek
In Stock
Sold by IT Hardware Direct Ltd £38.14
Intel Pentium D 925 Processor 2 x 2 MB cache 3GHz CPU -925 OEM - Intel
In Stock
Sold £41.10
Subtotal: £108.64
OR
1 x Foxconn Socket 775 Intel 64-bit Motherboard
1 x Intel Pentium D 925 Processor
1 x Intel Socket 775 Heat-Sink & Fan
TOTAL=£103.16
Related Pr oduct
Warranty Offender
Profile: enthusiast
More Information
Ok, the OEM processor is JUST the processor (no Heatsink/Fan). The retail has the CPU, and a heatsink+fan.
(if getting the OEM I reccomend the ZEROTherm Nirvana cooler)
Profile: stranger
More Information
ooh thanks :D
am i right in thinking the 1st option will work out cheaper?
i could only find this cooler
http://cgi.ebay.co.uk/zero-therm-c [...] dZViewItem
Profile: member
More Information
Also i believe OEM has a lesser Warranty
I looked at OCing my SNES but chickened out.
Profile: addict
More Information
I have a Pentium D and it's the hottest thing known to man! I would recomend trying to stretch a bit further to a core2, I can't wait to get rid of my Pentium D!
What will you be using the system for?
Profile: stranger
More Information
id be using the system for MMORPGs, other CD intalation games and just random desktop stuff.But nothing too extreme
How much would a core 2 cost.Would it be better
Profile: addict
More Information
you can get the pentium dual core (it's a core 2 essentially) for £35
http://www.eurowide-pc.co.uk/intel [...] 27874.html
Profile: addict
More Information
or for £60-70, the actual core 2 duos with the benefit of extra cache
http://www.google.co.uk/products?q [...] lnk=brsugg
Profile: enthusiast
More Information
If it was me, I'd try to find one of the Intel E21xx processors.  I have no idea which sites are good in the UK, but from this site:
http://www.ciao.co.uk/CPUs_5302007_2-intel
you should be able to find an E2160 for about the same price.
Clint
Work smarter, not harder!!
Profile: Honorary Poster
More Information
OR
TOTAL=£103.16
What are the parts that you need to complete your build? Are you transferring anything over to the new build or is the a total rebuild?
PSU Tiers
GPU Power usage
8800gtx/380w PSU!
s939 x2 4200/7900gs/2gb
Resident Jerk
Profile: Faithful Poster
More Information
The extra cache only offers a 2-5% improvement in performance.  It's not worth the extra money when on a tight budget.
E2160+Blood Iron+2GB Transcend DDR2-800.
Done and Done.
As was said, STAY WAY FROM PENTIUM D.  It is based on the old Pentium 4 architecture and Core2 beats it hands down.  The E21x0 line (even though it says Pentium Dual Core) is based on the Allendale Core.  The Allendale core uses Core2 Logic with 2 MB of L2 Cache.  Core2 Normally has 4 MB L2 Cache.  Short story?  It's a Core2 with 2 MB of Cache to start and the E21x0 line has 1 MB of that cache disabled.
TeamBAG Member
Profile: addict
More Information
Quite!
Profile: stranger
More Information
ill be using my current screen,mouse cd/dvd and stuff like that ..just the main bits need changing
The £35 duel core link is dead :(
Profile: addict
More Information
E2160 (1.8GHz):
E2140 (1.6GHz):
http://www.google.co.uk/products?q [...] ts&show=dd
E2180 (2.0GHz):
OK, I know that was a lazy way of posting prices but it works!
Profile: Ancient Poster
More Information
Shop for a e2140 elsewhere or something similar.
mi1ez beat me to it.
Message edited by evongugg on 02-05-2008 at 02:34:18 PM
Scruze my English!
Profile: addict
More Information
:D
Profile: stranger
More Information
sorry to bug you but why is the pentium d a 3ghz duel core but cheaper than E2180 when it is a 2.0 GHz
Also, i read that everyone who gets the E2XXX OC it. If i was to do that would it still count as duel core
ie " I oc'd mine from 2GHz to 2.4GHz" Does that mean its running at 4.8GHz or 4.4GHz?
Message quoted 2 times
Message edited by gamer383 on 02-05-2008 at 06:45:26 PM
Profile: journeyman
More Information
Because the myth of "More GHz = Faster Performance" is finally dead.  The Pentium D may be spinning its wheels faster via the Clock, but the Core 2 performs faster, gets things done faster without ramping the clock speed to a big number to trick you into purchasing it.
Disclaimer: I havent looked at benchmarks for an E21XX but my Core2 crushes my old Pentium even though I "lost" about 400MHz in clockspeed.
Profile: newbie
More Information
The E2140 appears to be 15-35% faster in benchmarks than the 3Ghz pentium Ds.  Go to Toms CPU benchmarks from the homepage.  Clock speed is not the whole story.  The E21xx are all faster at stock speeds the the fastest Pentium D plus cooler and, I believe, lower power consumption.
Resident Jerk
More Information
It doesn't scale like that.  Each core is running at 2 GHz or 2.4 GHz.  It's not 2x2.4 GHz.
As was said, the Pentium D is not nearly as capable as the Pentium Dual Core (Core2).  Core2 is so far above and beyond the Pentium 4 Architecture... it's not even comparable.
TeamBAG Member
Profile: stranger
More Information
:pt1cable:
E2180 Pentium 2.0GHz - Retail Cache: 1MB, FSB: 800MHz, Dual Core Processor
£52.66
£38.14
£29.40
TOTAL=120.20
Remaining-
Case
GPU
PSU
edit-Is this mobo good?How long do you think this new build will last.
Im looking at a Antec TP3-550-GB Truepower Trio 550w Uk PSU for £30..is that alright and compatible?
